ECU reflash vs E-Manage
Old Mar 2, 2006 | 06:20 AM
chickmagnet's Avatar
chickmagnet
Default ECU reflash vs E-Manage
hey i am just wondering if I get my ecu reflashed why might i need e manage. Dont they do the same thing. Or does both give you a superrior tune.by the way can someone explane both so that i can be clear about the two>thanks
Old Mar 2, 2006 | 08:53 AM
titanjc's Avatar
titanjc
The E-manage or a TurboXS UTEC should give you a superior tune, because they will allow a tuner to work on YOUR specific car, in person. It seems like when people already have a reflash and then go UTEC, they usually pick up an additional 10-15 hp over the reflash tune. Search around, there are lots of threads about this.
Old Mar 2, 2006 | 02:26 PM
slaponte's Avatar
slaponte
I went with the eManage to get my A/F ratior corrected precisely to my car needs. It was installed easy and tuned right on the dyno run by run, exactly to my car setup. Any changes I take it in to re-tune.
The only other thing the flash could do for you is change timming and remove the speed limiter/rpm limiter, which I didn't feel like paying so many $$$ to do. And, if later you change your car, you have to reflash...
Old Mar 2, 2006 | 11:30 PM
MR.OKKKK's Avatar
MR.OKKKK
and it cost $150 to get it reflashed...
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
