DIY for plenum spacer
Old Mar 13, 2006 | 07:10 AM
Zendem's Avatar
Zendem
Default DIY for plenum spacer
i'm getting a hold of a plenum spacer from MD and was wonering if anyone had any do it yourself information on installing this piece. Or if anyone has installed this on their car, would this be an easy install or am i going to need special tools or do anything to the car before its installed? thanks for any input
Old Mar 13, 2006 | 09:36 AM
99atlantic's Avatar
99atlantic
Rtfm
Old Mar 13, 2006 | 10:00 AM
HoldThisForMe's Avatar
HoldThisForMe
No special tools needed...should be instructions with it...follow them and everything will be smooth flowing.
Old Mar 13, 2006 | 11:31 AM
Zendem's Avatar
Zendem
Originally Posted by 99atlantic
Rtfm
what does this mean?
Old Mar 13, 2006 | 11:32 AM
Zendem's Avatar
Zendem
cool thanks
Old Mar 13, 2006 | 11:42 AM
99atlantic's Avatar
99atlantic
read the ****ing manual
Old Mar 13, 2006 | 09:40 PM
jondimellow's Avatar
jondimellow
hahaha. must asian. j/k.
Old Mar 14, 2006 | 06:41 AM
Zendem's Avatar
Zendem
jeez, fine get all butt hurt over my question lol
Old Mar 14, 2006 | 01:21 PM
DOHC's Avatar
DOHC
Cool
The instructions were excellent for the install, I had no problems. However, those who say you need no special tools are not telling the whole story. It is strongly recommended that you have a torque wrench capable of low in-lbs readings. You can get by with a regular socket and a drive handle (not a ratched) but I'd not recommend it. The biggest problems with the spacer installs have been related to torquing the bolts - too loose means air leaks, and too tight can mean a cracked or broken plenum. Either buy a cheap torque wrench from Sears etc. or see if you can rent one for a few hours. Wait until you have the instructions - they will explain everything.
PS - Don't be so sensitive. The RTFM comment probably wasn't meant as an insult, but really - rather than repeat everything in the manual in a post here, it is far better to read it first then ask questions.
Old Mar 16, 2006 | 07:35 AM
Zendem's Avatar
Zendem
thanks man but i am kind of thick skinned...if you notice i was laughing when that guy said read the fuking manual. But hey thanks again, i will try and borrow a torque wrench from someone and see how it goes. I was mainly wondering if anyone had done the install themselves and had some disaster or something thats what i really wanted to get at. reading the manuel is one thing but going throguh the job and having something go wrong is what i'm looking to avoid
Old Mar 16, 2006 | 07:48 AM
HoldThisForMe
The only problem I had with my install was that I dropped the damn socket and it fell all the way to the cover at the bottom of the motor...took me 20 damn mins to get it out lol
Old Mar 17, 2006 | 11:23 AM
Zendem's Avatar
Zendem
...making a mental note to self, dont drop the socket on the cover at the bottom of the motor
Old Mar 17, 2006 | 11:28 AM
EM-EFER's Avatar
EM-EFER
Be sure not to tighten any of the bolts in the bottom plenum and allow them to go into the cylinders.
^^^Top secret mod. 5WHP. Better spark
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
