Samco Induction hose
Old Apr 10, 2006 | 10:04 AM
MurphysZ's Avatar
MurphysZ
It's not rigid, it's just a pre-bent silicone hose that comes in a bunch of different colors. If it was $25 or something I would get as a dress up item but, at $125+, I just don't see the sence. No HP increase, and most likely weights a few onces more than a stock tube. I guess you have to ask WHY? ....I asked a rep at SEMA on Saturday, the only thing he said was about the colors then handed me a business card for the shop he worked at and said he could do better on the price, again I ask why would I want it? He didn't have a response......
So ask yourself, WHY? If you think it's worth it for you to spend $125 on something just to have it, go ahead and buy one otherwise, what improvements does it make over the factory one? I would rather have a carbon fiber one if I was going to spend the money on something useless that was just for looks.
Old Jan 28, 2009 | 01:16 PM
OCG35's Avatar
OCG35
Something no one seems to mention about the silicone hose (induction tube) and the CF tube is there is no accordion flex, which is why I am considering one… I’m sure the rippled flex part of the tube does not impeded airflow much, but a straight tube with no deviation in the bore would be better.
The one thing I’m not certain about with the Samco type tube is lack of mid-support bracket to mount from… it would just be throttle body and air box mount with no support in between – has anyone found this to be a problem?
Old Jan 28, 2009 | 01:21 PM
eat rice z33's Avatar
eat rice z33
I have the tube with my gruppe m intake. I have no issues, its not THAT soft its pretty rigid. Even though there is no support i have zero issues! I love it
Old Jan 28, 2009 | 01:27 PM
OCG35's Avatar
OCG35
Thanks for the response… so I presume the Samco length is a little shorter than OEM so it can slide within coupler on each end – correct? If so, what length coupler? 3-3.5” each?
Old Jan 28, 2009 | 01:30 PM
eat rice z33
The intake itself acts as the coupler. So its as long if not a tad longer than stock. mine i think is about 1/4 inch longer than stock. You dont need any couplers to run it you just need two hose clamps
Old Jan 28, 2009 | 01:31 PM
eat rice z33
If you look at the pics i have, you can see the bottom hose clamp in a couple of the shots
https://my350z.com/forum/intake/4134...lers-only.html
Old Jan 28, 2009 | 01:59 PM
OCG35's Avatar
OCG35
so the flex of the tube istelf is enough to bend into position on each end... thanks.
Old Jan 28, 2009 | 02:21 PM
eat rice z33
the intake is curved on the throttle body end and straight on the MAF end. you simply slide the tube over the throttle body and clamp with a hose clamp. then slide the straight MAF end over the MAF housing and clamp it down. thats it
Chris350z03
Oct 8, 2023 07:19 PM
SonnyWu
Nov 24, 2015 08:19 PM
EnjukuRacing
Sep 18, 2015 07:57 AM
