CCV below 55 Degrees?
Old Nov 9, 2006 | 05:04 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by semtex
So, having said all that, what is the 'true' CCV switching temperature? i.e., the one with no margin? And what is at risk if one forgets to open up the CCV below this temp? Permanent damage? Or just a temporary degradation in performance until either things warm up again or s/he remembers to open the CCV?
I can't say exactly what will happen if the throttlebody gets iced up. How much ice are you talking about. There can be an infinite number of ways and degrees if icing.
The minimum switching temperature is any temperature that won't allow icing to occur. And this is variable. It is based on the variables of ambient temperature, humiditiy, diving time, driving style and a whole lot of variables that can't be readily predicted.
If you don't want to switch the CCV at 55'F, or don't know how/when, get the Copper Iso Thermal.
The Copper is automatic plug and play. You don't have to consider temperatures or deal with switching a CCV.
Old Nov 9, 2006 | 05:13 AM
semtex's Avatar
semtex
Thanks. I think I might do just that. So after I install the Copper, I would turn the CCV back open and leave it, right?
Old Nov 9, 2006 | 06:53 PM
Hydrazine's Avatar
Hydrazine
Yes.
Old Jan 5, 2007 | 07:54 PM
led's Avatar
led
just wanted you guys to know that I love this forum. Whenever I have a question I just need to search and you guys answer everything.
You guys rock!
Old Jan 5, 2007 | 11:42 PM
CaliTouring's Avatar
CaliTouring
Im sorry i know im a nubie but whats a CCV
Old Jan 6, 2007 | 12:48 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Coolant Control Valve. It comes with the Iso-Thermal Plenum Spacers from Motordyne.
Old Jan 6, 2007 | 08:27 AM
JFAIR's Avatar
JFAIR
i'm about to install my 5/16 spacer. do i have to install the ccv to get the max performance out of the spacer? what are to pros and cons of the ccv? i also live in an area where it might get down to 30 deg in the morning. if i do install the ccv should i just leave it closed?
Old Jan 6, 2007 | 08:58 AM
3hree5ive0ero
Retired Admin
In my opinion the CCV doesn't really do much. It CAN, but most of the time you won't need to adjust it and even when you do, you'll forget or be too lazy. I recommend that you don't install the CCV, especially because it requires cutting of a stock hose. As far as operating the CCV goes, it's in the manual that you get with the spacer or mrev2.
Old Jan 6, 2007 | 03:40 PM
cturnbull802's Avatar
cturnbull802
i had my TB bypassed in my civic in michigan. year round no problems!!
Old Jan 8, 2007 | 11:39 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Let me post something to update this thread...
I went on a skiing trip, so I traded my dad the Z for his SUV. I forgot to open the CCV, even though it was about 40 degrees F where he lives. Nothing bad happened to the Z in the time that he was driving it. (Maybe letting the engine warm up plays a strong role)
But then again, if the humidity were higher, who knows. I also doubt he went WOT a lot.
Old Jan 8, 2007 | 11:44 AM
Nexx's Avatar
Nexx
+1.. The weather in TX fluctuates constantly so I have been closing/opening the CCV. I'd like to leave it closed until I come very close to the point where it's imperative that I need to open the CCV.
ive had mine permanately closed off so i dont have a choice to turn it off or on. ive had zero problems in sub freezing temperatures so far.
Old Jan 8, 2007 | 11:52 AM
rfinkle2's Avatar
rfinkle2
i have an 06, and the motor runs really hot... I haven't had a problem yet leaving it closed.
lapham3
Oct 7, 2022 03:15 PM
TrackFiddy
Sep 24, 2015 11:40 PM
CrowzRSA
Sep 21, 2015 04:00 PM
