HFC and A/F ratio
Old Apr 12, 2006 | 03:12 AM
350Z_LMS's Avatar
350Z_LMS
Default HFC and A/F ratio
Hello all. I have Crawford HFCs installed with a NISMO exhaust and all is well with the combo (apart from a few install problems, sorted with spacers - see other threads). Now, here's the question...after the install, I did not reset the ECU and the combo did not throw a CEL: anyone actually measured what effect of installing HFCs is on the A/F? I mean, the "HF" in HFCs mean a less restrictive flow of the exhaust fumes, right? If no CEL shows, then the ECU still thinks all is well (or thereabout)...but I am pretty sure that A/F will be affected. My question is by how much...
Old Apr 12, 2006 | 03:15 AM
Mike Wazowski's Avatar
Mike Wazowski
you should have installed a wide band before and after. No way for us to know how much your A/F would change since all 350Z's take to Mods differently.
Old Apr 12, 2006 | 03:31 AM
350Z_LMS's Avatar
350Z_LMS
Anyone installed a wide band before and after by any chance? Do we know for sure the ECU hasn't gone into safe mode without throwing a CEL?
Old Apr 12, 2006 | 03:32 AM
Mike Wazowski
You will not throw one with HFC's only some models with throw it when the run Test pipes.
Old Apr 12, 2006 | 04:55 AM
There are 2 subjects to address:
a. SES light because of excessive emissions? High-flow catalytic converters are designed to pass emission tests; therefore you should have no SES because of emission problems.
b. Do mods such as high-flow catalytic converters change the air:fuel ratio and how much? Yes the air:fuel ratio has been altered. And no I don't have the faintest idea how much.
Old Apr 12, 2006 | 05:44 AM
350Z_LMS's Avatar
350Z_LMS
Thanks david, that sums up what I think and I am trying to find an amswer to your b.
etkms
Jun 19, 2022 06:30 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
FromGtoZ
Sep 20, 2015 03:41 PM
Shane86
Sep 17, 2015 05:33 PM
