Strup test pipe installed.
Old Apr 13, 2006 | 05:51 PM
Changvi's Avatar
Changvi
Default Strup test pipe installed.
Just had the Strupp test pipe installed. The initial sound was very nice, but as the RPM rose, it got kind of raspy. I'm not sure if its normal or what not. the test drive impression was definitely well worth doing. It felt some lower end was lost, but top end was pretty impressive only after 4000 rpm. It kept on pulling through redline. Not sure what the HP increase is, but definitely noticeable. John from Exact motorsport told me to reset the battery because it might run a bit rich after the install. So i did what he told me, and wow, defintely sounded a bit different, and the car felt a bit stronger. Quality of the test pipe was top notch. Its a must for those who want na power.
Old Apr 13, 2006 | 06:02 PM
Photos would be nice but...
Test pipes are a proven performance bolt-on. I’m sure that you looked at the OEM catalytic converters OFF the car. Its a wonder that any exhaust gets through them.
Old Apr 13, 2006 | 07:15 PM
Zincognito's Avatar
Zincognito
im waiting to install my invidia test pipes to go along with my JIC y pipe but i just couldnt get the damn cats off the car today!! im pissed
G
Old Apr 13, 2006 | 07:46 PM
StillAlive2029's Avatar
StillAlive2029
what was the problem???
Old Apr 13, 2006 | 09:47 PM
n3z50's Avatar
n3z50
Dude i had mine installed yesterday..so, far i am loving it.....allthough i haven't reset my ecu.
Old Apr 15, 2006 | 06:58 AM
Zincognito's Avatar
Zincognito
taking the bolts off the cats is just rediculous not to mention not having the proper tools. im gonna try again this weekend. when you do something like this, you have to reset the ecu?? if so, how do you reset it??
G
Old Apr 15, 2006 | 07:25 AM
Changvi's Avatar
Changvi
You can reset your ECU by simply disconnect the negative terminal from the battery and wait for about a minute or so, then reconnect the battery.
Old Apr 15, 2006 | 07:28 AM
Zincognito's Avatar
Zincognito
hmm........what does reseting the ecu do?
Old Apr 15, 2006 | 10:33 AM
Changvi's Avatar
Changvi
reset the ECU to learn the testpipe's increase flow. The car ran a bit sluggish before the ECU reset. After the reset, the car ran so much better and the power was more noticeable.
Old Apr 15, 2006 | 10:53 AM
plumpzz's Avatar
plumpzz
The rasp is normal with those test pipes. It only happens at around 3500 till 4500, and after that the engine really takes over. I know what you mean by the huge power boost after 4000 rpm. It feels like VTEC, and ironically the power is felt as soon as rasp starts.
Old Apr 15, 2006 | 10:57 AM
Changvi's Avatar
Changvi
Is it also normal to have exhaust fumes inside the cabin with the ac drawing air from outside? I can smell the fumes when it is drawing air from outside. But as soon as i have the air set to recirculate, the fumes stopped. Do i have a leak? I also noticde water drops from one of the connecting point of the exhaust at the rear.
Old Apr 15, 2006 | 01:59 PM
kalima275Z's Avatar
kalima275Z
I put on UTR resonated test pipes and they sounded like Kaka. However, I also got my Utec and ran the "Intake/Exhaust" map and the raspy sound became less noticeable.
Old Apr 15, 2006 | 02:17 PM
RNL323's Avatar
RNL323
Mod My Ride
Need to be disconnected for 24 hours, my friend, not a minute or so... IMO, with test pipes, your better off with a reflash or piggyback...
Old Apr 15, 2006 | 05:14 PM
guitman32's Avatar
guitman32
ECU Gas Pedal Reset Procedure:
1. Turn ignition switch to on.
2. Wait 3 seconds
3. Fully depress and release the accelerator pedal 5 times within 5 seconds.
4. Wait 7-10 seconds
5. Fully depress accelerator pedal for approx. 10 seconds. The SES light will start to blink quickly indicating diagnostic test mode has started.
6. Release accel. pedal and wait 5-10 seconds.
7. Fully depress the accel. pedal for 10 seconds. The SES light will change to blinking slowly, indicating erasing ECU memory.
8. Release accel. pedal and turn ignition switch to off.
9. Restart the engine. The ECU has been reset.
The above is how you reset the ECU without disconnecting battery for 24 hours. Timing is key, and if by step 5 the SES doesn’t blink, your timing is off so start again. Just remove the key for 10 seconds and try again.
Old Apr 15, 2006 | 06:51 PM
Changvi's Avatar
Changvi
i just had Apexi afcII installed instead of reflash. I had it set at 8% lean because i'm running a bit rich. The car felt a lot stronger, and the acceleration was quicker. Some people have said that it doesn't really do anything, but i don't think thats entirely true. AFCII is well worth the investment if it is tuned and programmed correctly. I'm going have my car dynoed and adjust the afc after. I'll keep you guys up to date.
Old Apr 15, 2006 | 07:32 PM
bacalhau16's Avatar
bacalhau16
I have worked with a few SAFC's and they're cool. I have had good luck with them in other cars. Curious to see how well it works in the Z. Good luck!
Old Apr 15, 2006 | 08:32 PM
Is it also normal to have exhaust fumes inside the cabin .
No. Check for leaks.
Old Apr 15, 2006 | 09:20 PM
bacalhau16's Avatar
bacalhau16
well, actually with test pipes, the smell of ur exhaust will increase and the car will smell more often. Depending on how bad the smell is really, you could have a leak, but often, most people who had installed their test pipes mentioned bad smell of fumes.
Old Apr 15, 2006 | 09:26 PM
plumpzz's Avatar
plumpzz
If you pull air from outside, yes itll smell like gas. I have that and i know i dont have a leak.
Old Apr 16, 2006 | 06:52 AM
Changvi's Avatar
Changvi
How do you check for leaks??
