Plenum Spacer
Old May 17, 2006 | 07:13 AM
nykrnva's Avatar
nykrnva
Default Plenum Spacer
I have an 06 track. How easy is it to install a Plenum Spacer? Will it void my warrenty? I see everyone either suggests this or a Pop Charger for first mods.
Old May 17, 2006 | 07:53 AM
Ztalker's Avatar
Ztalker
make sure to torque every single bolt correctly, otherwise your asking for trouble.
Old May 17, 2006 | 08:10 AM
mdracer76's Avatar
mdracer76
I predict that this will be you
... and here are your search results...
https://my350z.com/forum/search.php?searchid=1366423
Old May 17, 2006 | 08:16 AM
Escobar's Avatar
Escobar
yea, im not sure about the warranty but the plenum spacer and intake are great mods that are cheap and have relatively good power gains with easy installation. Call the dealer.
Old May 17, 2006 | 08:18 AM
Ayankees2772's Avatar
Ayankees2772
yep escobar is right. Do not over tighten the bolts...
Old May 17, 2006 | 08:21 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
the plenum spacer is supposed to be a do it yourself mod.. most dealerships won't know the difference if you put that on and even if they do, it will not void your warranty. popcharger is also a good mod and is very easy..
i'll be installing MREV2 today hopefully (if it comes in) which is like installing a spacer so i'll let you know how it goes
Old May 17, 2006 | 09:10 AM
GMZ's Avatar
GMZ
I picked up my spacer from Tony yesterday. Im on my way from CA to VA so Ill have to wait until I get there. Looks very easy to install. Need to find a in/lb wrench though.
Old May 17, 2006 | 09:43 AM
Download the instructions from motordyne.com. If you are familiar with the terms and tools, do it yourself. If the instructions sound like Greek, pass on installation.
Old May 17, 2006 | 10:02 AM
nykrnva's Avatar
nykrnva
Thanks guys. I think i am going to look a little further into it. I already have a torque wrench, our wheels need it.
I see mixed resonses about the fornt stru tower brace, do i need to remove this?
Old May 17, 2006 | 10:04 AM
3FITTTY's Avatar
3FITTTY
not with a 5/16 spacer, anything bigger you will..
Old May 17, 2006 | 10:11 AM
nykrnva's Avatar
nykrnva
I read that on the motordyne web page. Thanks. i have 1 other question.
I read in one of these threads that it will not make a difference for the 06 engine, that true?
Thanks for all the replies. I know this subject is talked about allot, but no clear answers
Old May 17, 2006 | 01:47 PM
Z_freak's Avatar
Z_freak
It just will not make as big a difference...the air flow issue to the front cylinders in the earlier models was "corrected" in the 06. I am going to do one also and I have an 06, I have seen on this forum others get good gains from them on an 06....i guess we'll see...
Old May 17, 2006 | 02:05 PM
3hree5ive0ero
Retired Admin
Apparently, the mail man dropped off my MREV2 without me knowing it.. so it's sitting here next to me..
I just can't install it because I don't have an inch-lb torque wrench.. also waiting for my car to cool down..
Tony said that it shouldn't be too hard installing it yourself.. At a relaxed pace, it should take 1.5 hrs to do.. 2 hrs if your doing it with a friend, drinkin a few beers and talking.. 45 min for a pro like him..
Old May 17, 2006 | 03:24 PM
OCG35Coupe's Avatar
OCG35Coupe
make sure thats a inch-lb torque wrench.
Old May 17, 2006 | 03:40 PM
3hree5ive0ero
Retired Admin
yea.. thas what i don't have.. I'm going to sears tomorrow to get one.. also a set of metric sockets..
Old May 17, 2006 | 04:41 PM
flipmoder7's Avatar
flipmoder7
I installed mine without a torque wrench and had no problems at all. It's been three days and no air leaks or broken bolts. I just used the nut driver that he recommended in the directions and used leather gloves. Btw, I have a 04 g35 6mt if that makes any difference with the bolts.
Old May 17, 2006 | 06:48 PM
bacalhau16's Avatar
bacalhau16
ya, i installed mine with a screwdrive socket thing. Havent had any problems with it what so ever. Was such and easy install its not even funny.
Old May 17, 2006 | 07:04 PM
undrgnd's Avatar
undrgnd
Didn't you have to remove the strut bar before the installation and then remount afterward with washers to allow fitment?
Old May 18, 2006 | 06:27 AM
nykrnva's Avatar
nykrnva
i would not touch them bolts with out a torque wrench. Certain bolts i would not pay any attention to the recomended torque setting, but those i would.
i think i am going to go ahead and get the spacer for the 06. Cheap mod. I want an HKS, but 1500 is crazy.
Old May 18, 2006 | 08:10 AM
3hree5ive0ero
Retired Admin
i would definitely follow directions especially when it specifically specifies for the user to use the torque-wrench.. just me though
