bolt ons & utech
Old Jun 5, 2006 | 07:40 PM
nth.zed's Avatar
nth.zed
Default bolt ons & utech
I have the nismo cat back, super high flow cats, and typhoon cai. Would a utech give me any better performance? Would it interfere with my factory warrantee?
future mods will require the utech, so should I just buy now?
Old Jun 5, 2006 | 07:45 PM
Cannysage's Avatar
Cannysage
you need to dyno your car and see if you're running the current mods safely. It's not always about performance gains. but yeah, you'll definitely give you more power.
Old Jun 6, 2006 | 11:19 AM
ACEMAN's Avatar
ACEMAN
Master
Once you dyno your car you will be able to see what your A/F ratio is. If you are running to lean you are losing HP. With our cars you would want to have your A/F ratio around 12.8 to 13.1 up to 5800 rpm and then richen it up to about 12.5. All cars are different depending on Mods.
The first thing you need to do, and everyone will tell you the samething. Get a base line dyno and go from there. Post up your dyno graph and we can see what is going on.
Hope this Helps
Later
Aceman
Old Jun 6, 2006 | 12:06 PM
jonnylaw's Avatar
jonnylaw
I don't mean to jack the thread--but I was wondering if you guys could take a look at a dyno run I just did w/ Mrev2, 5/16 spacer--I'm also looking to install jdm wledina exhaust, and potentially utec if the A/F is not good--Is it ok for the car to run rich as opposed to lean?
AbrasiveRaysive
Sep 20, 2021 02:29 PM
wanderingstuden
Jan 28, 2016 07:03 PM
