Dual Exhaust/Test Pipe RASP proven fix
Old Dec 11, 2006 | 05:49 AM
z-u-later's Avatar
z-u-later
Yes, it's a proven fixed! I have headers & test pipes, and this setup fixed these issues. I also regained the VQish's awesome sound but much deeper growl than stock. You will definitely gain some torgue also. I checked around for the best deal on the Magnaflow x-pipe muffler and the best deal is at justmagnaflow.com. And free shipping too! It arrived in three days so great service.
Old Dec 17, 2006 | 01:16 AM
Roger V's Avatar
Roger V
How much does it cost to have an x-pipe installed?
Old Dec 17, 2006 | 07:15 PM
z-u-later's Avatar
z-u-later
It cost me $100 to have the two resonators in my Injen SES removed and replaced them with the Magnaflow x-pipe muffler. It took about an hour to complete the install.
Old Dec 18, 2006 | 05:03 AM
ACEMAN's Avatar
ACEMAN
Master
Depends on who does the work. I spent $50.00 for mine. But expect to pay between 50 and 100.
Todd
Old Dec 18, 2006 | 06:32 AM
gringott's Avatar
gringott
I picked up Zachcrosen's system with the xpipe on the injen, I have a TT setup. For this install I used my kinetix HF cats, and replaced all gaskets.
My impression: 0 rasp. None. System is very quiet, quieter than the NISMO. I will run the system like this until next summer, then I will swap the HF cats for the set of resonated TP's I have, and see what that sounds like. For the first time in months I am not embarrassed to drive my Z, the SVR Tech 2.5 inch custom exhaust with xpipe was TOO loud for me. This system may be too quiet, but I definitely like too quiet over too loud.
Old Dec 27, 2006 | 09:08 AM
04_CS_Z33's Avatar
04_CS_Z33
I just had this x-pipe installed. It definitely sounds a bit quieter. I'll see how much louder it gets when I get test pipes installed. Hopefully it doesn't get raspy.
Old Dec 28, 2006 | 04:35 AM
ACEMAN's Avatar
ACEMAN
Master
You should be fine. I have Kenitix resonated test pipes on right now. No rasp.
Let us know
Later
Todd
Old Dec 28, 2006 | 06:45 AM
04_CS_Z33's Avatar
04_CS_Z33
Did anyone with the Magnaflow(11385) and the Injen straight tip have any problems with lining it up? The shop told me that the x-pipe in/out was set a bit wider then the exhaust. This caused them to have to cut the little bracket from Injen and add some length to it.
Old Dec 28, 2006 | 08:08 AM
ACEMAN's Avatar
ACEMAN
Master
You wont need the bracket anymore with the X-pipe. The muffler braces things the way the bracket does. So adding length to it is a waste of time.
Todd
Old Dec 28, 2006 | 10:01 AM
extreme4377's Avatar
extreme4377
Definitely check out the Fast Intentions Intimidator system. I switched from the Injen Track Edition Ti Tip True Dual to the FI Intimidator and am much, much happier with the FI. Its got getter gains, better noise, doesnt get you pulled over for being too loud, no drone what-so-ever, incredible quality and some of the best customer service to boot. +1 for Fast Intentions!
Old Dec 29, 2006 | 03:55 AM
ACEMAN's Avatar
ACEMAN
Master
I agree, if you dont already have a true dual. But if you do and you want it to sound better, this works.
I know my buddies car sounds nice with the Fast Intentions exhaust. But i still want to see what it sounds like once the cats are removed.
Later
Todd
Old Dec 29, 2006 | 06:09 AM
diablo25mn's Avatar
diablo25mn
A local exhaust shop and I got around to shooting some ideas on a setup with x-pipe. Check on my post with pics and a vid:
https://my350z.com/forum/showthread....=1#post3137001
Overall i'm asking the same question how would this sound with test pipes. I actually have no drone with this setup and its quiet at idle, progressively getting louder through the RPM band.
Old Dec 29, 2006 | 04:16 PM
04_CS_Z33's Avatar
04_CS_Z33
Got UTR resonated test pipes installed tonight. Sounds good, no rasp, hardly any drone, sounds like a loud/deep stockish exhaust.
I'll try to get clips up tomorrow.
Old Jan 3, 2007 | 11:29 AM
xedes's Avatar
xedes
tag for sound clip.
Old Jan 3, 2007 | 12:07 PM
CaliTouring's Avatar
CaliTouring
This is a great thread for I just purchased the Injen SES and will be taking this idea into consideration if I am not happy with the Results that the exhaust outputs.
Old Jan 15, 2007 | 05:52 AM
Manu's Avatar
Manu
Hello,
Just bought a SES too, and thinking about doing this setup.
Sorry if this was answered before, but were there adjustments to be made to the Injen so it fits the Magnaflow X-pipe? Or did the tubes line up perfectly ?
Thanks in advance.
Manu
Old Jan 15, 2007 | 07:13 AM
z-u-later's Avatar
z-u-later
I have the Injen SES and installed the Magnaflow x-pipe muffler. The x-pipe muffler will lineup perfectly if you install it where the two resonators are located. Before you weld the joints, make sure the rest of the exhaust system are aligned correctly and not touching any part of the frame.
Old Jan 15, 2007 | 07:30 AM
  #38
Manu's Avatar
Manu
That's great information. Thank you very much for your help.
Old Jan 26, 2007 | 03:30 PM
  #39
Nismo 350z's Avatar
Nismo 350z
Would this x-pipe work on the HKS ex. ?
Old Jan 26, 2007 | 06:39 PM
  #40
jondimellow's Avatar
jondimellow
so this is like a resonator?
