Crawford Plenum install Issue, PLEASE HELP!
OK first off, I am a MORON! Yes a MORON! Having said that; I got my Polished Plenum from another member here (beddow) THANX again Eric I love it!
Anyway, as I am installing the 4 bolts that go into the lower collector, on the last one, I over tightened and the head popped off, what can I do? Can I leave it?? Or do I need to figure out a way to back it out and replace it? I did finish the install and started it up and it is running perfect (and fast!).
If anyone knows PLEASE let me know....Thanx
Datsun240Z71: Thats what I was thinking but I will give Doug a call this morning...Thanx for the advice.
Zincognito: Here you go!
purty cool call.
quick Q on your plenum install: did you need any other added bolts, really, other than the 4 that close the lower piece? got Kinetix myself from a guy on here, but it didn't come with any bolts. finding a hard time figuring out what I need before I start the install. any tips?
Originally Posted by suprpwr
purty cool call.
Crawford Plenum Installation Manual in PDF ... from Crawford site
http://www.crawfordzcar.com/support/...stallation.pdf
Are your PIAA's the black finish? They look sweet
eTraxx: Thanx, I have that but doesn't help my broken bolt problem
Brick-Z: Yeah they are the Gloss Black I love them! Thanx!
Vq.turbo.DremZ: I'll take one as soon as get home. The Crawford Strut does clear the Injen fine, no problems...
OK guys straight from Doug at Crawford..
My question to him:
The lower 4 bolts when putting on your Plenum, I broke the head off of one! The bolt went all the way in with Loctite all around, just the head came off because of my over exuberance! is this OK? Can I drive it or call a tow truck.
Doug:
AS LONG AS THERE IS LOCKTITE ON IT YOU SHOULD BE OK
Doug Stewart
Crawford Z Service
615-327-4159
My question to him:
Doug:
Doug Stewart
Crawford Z Service
615-327-4159
I hope that when you broke it off that you have the end of the bolt. I've heard of people unknowingly dropping them into the engine.
. Also, some people weren't noticing the torque specs. in the directions that were in in/lbs. not ft/lbs.
Originally Posted by Vq.turbo.DremZ
Could you take pics of your engine bay? I want to know if the Strut clears the injen and if there is enough space for my arc oil catch.
Yeah Jersey weather blows, well for the last couple of days anyway. If its not too much trouble could you take a couple of pics where the main pipe off the TB connects to the silicone connection? I'm trying to judge the amount of room needed for a different filter. (Section by driver side headlight and stock airbox inlet. I never have been happy with the Injen and AEM oiled filter elements, plus my injen has YET to come in so i have some downtime to look parts while my other parts are in transit. Any help is much appreciated.
