stock exhaust bolt sizes...
Old Jul 16, 2006 | 09:46 PM
wren57's Avatar
wren57
Default stock exhaust bolt sizes...
Installed my stock exhaust tonight but can't find nuts that go on the carriage bolts welded into stock exhaust. What size are they?
Going to be fun driving to the store/work in the morning with these huge exhaust leaks...
Old Jul 16, 2006 | 10:15 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
i believe 14mm or 15mm?
Old Jul 16, 2006 | 11:11 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
you can use any higher strenth bolts / nuts that fit..
Old Jul 17, 2006 | 06:00 AM
wren57's Avatar
wren57
No, you can't, because the stock exhaust has carriage bolts welded into it... at least mine does.
Old Jul 17, 2006 | 06:03 AM
m1james@bellsou's Avatar
m1james@bellsou
Ride your bike to the hdw store, if it falls off or hits the ground, contacts something and melts/damages it it could get expensive.
Old Jul 17, 2006 | 08:36 AM
Jason@Performance
Performance Nissan
correct, for the one with studs you can use any NUT...
If there is no stud, then you can use any nut and bolt combination... as long as they are higher strenth bolts... (will save you having to break a bolt off when changing next)
Sorry I should have been more clear...
Old Jul 17, 2006 | 10:09 AM
wren57's Avatar
wren57
ok, that still is no help, I need to know the size of the nut... I obviously know you can't use any size
Old Jul 17, 2006 | 10:21 AM
Jason@Performance
Performance Nissan
I think they are 10x1.25 thread pitch...
I know you cant use anysize... but what ever threads on and fits will work...
Sorry I should have made my first post say...
You can use any Nut that has the same thread size and pitch of the exhaust studs when exhaust studs are inplace.
If there is no stud you can use any bolt and nut combination that fits.
I recommend using higher strenth nuts / bolts so the bolts will be easly removed after being used.
I hope this is clearer now... ?
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Li1ag
Sep 28, 2015 02:07 PM
