Want to clear this MREV thing up one last time..
Old Jul 19, 2006 | 08:34 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by blkonblkprime
does the mrev+ work well with an aftermarket plenum?
I would assume it will produce the same (or similar) results as a spacer.
Old Jul 19, 2006 | 08:41 PM
Hydrazine's Avatar
Hydrazine
Originally Posted by Nismo 350z
What if the AFR is set at 13.3? Can you run them together then? Because I reflashed and Tadashi set my AFR at 13.3 but I am running the Rev-up lower plenum. If I get the MREV2+spacer, do I need to reflash again?
You don't necessarily need to get a reflash again but install the mods in sequence with a dyno in between. That will tell you if you need to get a reflash before the next mod or not.
And I can't predict where your A/F will go if you have a 287 engine tuned with a REVUP lower collector and then move to a MREV2... I havn't seen that combo before.
Install the MREV2 and get a dyno. You will probably be just fine but post your results here for review and analysis.
Old Jul 19, 2006 | 08:49 PM
ASTIG_Z's Avatar
ASTIG_Z
Originally Posted by Hydrazine
Every dyno to date shows the 5/16" spacer always making more area under the curve.
+1, Thats why i got the 5/16 first. MREV2 later on. Maybe i'll get the MREV2 if i see dyno's with reflashing the ECU makes good gains.
Old Jul 19, 2006 | 09:10 PM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
You can. Higher peak, but it makes less area under the curve.
Yep - on the spot - small TQ drop with the 1/2"...
Rick
Old Jul 19, 2006 | 09:46 PM
clearsector's Avatar
clearsector
what gains should be expected on the revup with both?
+1
are there any dynos with the revup mrev2-5/16 spacer combo?
thanks in advance!
Old Jul 20, 2006 | 03:50 PM
Hydrazine's Avatar
Hydrazine
Yes. They have been recently posted by a couple different G35 guys.
Dyno plots included.
Old Jul 22, 2006 | 04:45 AM
Zincognito's Avatar
Zincognito
Correct me guys if i am wrong, but no one has answered the Original question straight forward...... Im asking also because i have a friend that is undecided which Motordyne product to purchase for his 06 Rev Up.
Old Jul 22, 2006 | 05:51 AM
masterj26's Avatar
masterj26
If you have the REVUP engine (in the 6MT) do both the MREV2 and the spacer together. Its definitly the best plenum mod you can do.
If you have a non-REVUP engine (in the automatic), do one or the other. You can always add the other mod later, but first get a dyno before doing the second mod. If your A/F ratio is in the 13's or lower, you can do the other mod. If your A/F is in the 14's or higher, get a reflash or engine management first.
Tony said that the best for the REVUP engine is both the spacer and MREV2. I am almost positive that there are dynos on here for the combination
Old Jul 22, 2006 | 09:32 AM
Looks like we have not straightened out the MREV thing for the last time. And for many members we never will.
Old Jul 22, 2006 | 09:56 AM
Mazinger Z's Avatar
Mazinger Z
That's sux because I was ready to buy the Mrev2 + spacer but didnt get my questions fully answered either...even with the dyno plots (varies from car to car) no one can really answer this question: What are the gains/losses on the rev ups with this mod?
Old Jul 22, 2006 | 09:58 AM
masterj26's Avatar
masterj26
the gains will vary from car to car. Just like some cars baseline at 220's and others baseline 240's or higher
Old Jul 22, 2006 | 10:01 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
You also have to understand the fact that not all cars will respond the same to the same mods. Plus, only 120 something people have MREV2 and Tony just restocked them. So, mathematically, even less people have MREV2 for their revups. You will get more than enough dyno charts for revup with spacer and MREV2 or just one or the other soon.
Old Jul 22, 2006 | 12:51 PM
Mazinger Z's Avatar
Mazinger Z
Yea, just waiting for a clearer analysis of what the actual gains are...there were more explanations on the old mrev/mrev+ mods where dynos were more consistent- like what the actual gains are, where it lost power, etc...but on the mrev2...no one really has a clear analysis of the dynos (gains/loss)..if i'm going to invest $700... i would like to know what i'm getting/losing~
Old Jul 22, 2006 | 01:02 PM
dingobiatch's Avatar
dingobiatch
I'm going with the MREV+ cause I found it used for a good price, would the gains with the MREV2 be much better? (This is with the 5/16 spacer.. on revup)
Old Jul 22, 2006 | 01:21 PM
Hydrazine's Avatar
Hydrazine
I thought I answered this one.
Definitly do both together on a REVUP. The MREV2 makes more TQ and the spacer makes more HP.
For specific details on what it does to the power curve, there are independant dyno plots posted by members here on MY350Z and on G35Driver.
As a general idea of what it will do, you can see the MREV+ dynos posted on our website. MREV2 with a spacer is everything MREV+ was, but MREV2 has even more machining. There are also recent dyno plots of people who switched from MREV+ to MREV 2 and showed significant gains.
Tony
Old Jul 22, 2006 | 08:29 PM
Zincognito's Avatar
Zincognito
OK......Tony, if you had to pick between one of your products as your first mod for an 06MT rev up Z, which one would it be?? mrev2 OR spacer???
I dont want you to think that i am doubting your products or anything of that nature. Im just curious as to which one would you purchase first. Thanks
G
Old Jul 23, 2006 | 04:37 PM
Hydrazine's Avatar
Hydrazine
If only one, definitly the MREV2. It will make very significant TQ gains.
A spacer by itself (on a REVUP) will do little or nothing.
Sorry if I wasn't clear the first time.
Tony
_bit
Oct 2, 2015 07:49 AM
