Spacer on rev up....
Originally Posted by bofa
Damn.. all this reading and I still don't know what to do..
If you have the manual, use both the spaccer and MREV2 together.
Hope this helps.
Tony
definitely some very informative info Tony, thanks for that
we had a local meet yesterday and i did a run with a 287hp car, 2nd gear pull from about 50km/h. He took off slightly before i did but we maintained the same gap till about 90 when he shifted and i kept revving in 2nd. I reeled him in quite easily at the top of 2nd, into 3rd and i started pulling
the rev up engine is exactly that, its advantage is in the top end
but you're right, for those wanting more low-mid torque, the MREV 2 is the way to go
though i will say i gained quite a bit of torque switching to crawford high flow cats
Hahaha! Thanks ***!
BTW - Now that I have a Dynapack 4000 on the way, a lot of serious research can be done.
A completely new generation of flow diodes (test pipes), a totally different configuration of cats and a exhaust systems that will be like nothing else on the market.
The Z will be mounted on the dyno where it'll stay for at least three months or untill I have created the most refined exhaust system.
Originally Posted by Hydrazine
Hahaha! Thanks ***!
Keep us posted and Keep up the Great work !!!
