pop charger question
Old Aug 14, 2006 | 06:35 PM
ofl0926's Avatar
ofl0926
Default pop charger question
i had a question. i did my fair share of searching and found nothing so here it gies. will a g35 pop charger fit into a 04 z.
let me know thanks
Old Aug 15, 2006 | 01:27 AM
Are the part numbers the same?
Old Aug 15, 2006 | 02:36 AM
Cannysage's Avatar
Cannysage
I believe popcharger will fit into any car, if you force it hard enough.. every car that I buy from this point on will have a popcharger
Old Aug 15, 2006 | 02:38 AM
taurran's Avatar
taurran
let me know thanks
Yes, but if you want to install the heat shield you will need to buy one that fits a Z.
Old Aug 15, 2006 | 04:57 AM
ofl0926's Avatar
ofl0926
thanks guys
Old Aug 16, 2006 | 11:15 PM
orhanz33's Avatar
orhanz33
i bought my popcharger new from my friend, who had originally ordered it for his g35. you can get the heatshield direct from jwt for like $20. well worth it imo. i placed my hand on both sides of the heatshield while the car was running, and it was amazing how much hot air it actually blocked out from the filter area!
Old Aug 17, 2006 | 08:28 AM
Q45tech's Avatar
Q45tech
Always consider that hot underhood air can quickly negate any gains from removing restrictions. For every 11F hotter air the density drops 1% and so does the power output.
The combo MAF air temp sensor cannot be fooled easily.
Always a good exercise to measure the restrictions [at torque peak and redline rpm] in front of MAF before spending on any modifications unless sound is the primary reason for such mods.
Search Ebay for Dwyer Manometer series 475 [or a Magnehelic gauge] something that can read 7 or 10 or 14 or 28" [1.0 psi] full scale water column with accuracy.........normally the losses in front of MAF are < 7.0" water column. [~~ 0.25 psi] at 7,000 rpm.
issyz
Jul 2, 2017 03:04 PM
_bit
Oct 2, 2015 07:49 AM
