Unlimited Tuning Carbon Fiber Intake Filter
Old Aug 31, 2006 | 04:46 PM
ZlleH's Avatar
ZlleH
Default Unlimited Tuning Carbon Fiber Intake Filter
I hope this is not a repost, the search function is not what it used to be, it gives back such a broad search result that it's not even a search at all.
Has anyone seen this yet or have it installed? More info would be appreciated.
Unlimited Tuning Carbon Fiber Intake Filter:
http://www.grubbsperformance.com/Mer...gory_Code=350Z
Old Aug 31, 2006 | 10:27 PM
Chebosto's Avatar
Chebosto
generally you would want to make sure your airfilter gets as much air around it as possible.. not suffocate it. hence the switch from covered air filter box to open-air element filter (ala pop charger). even the Gruppe M CF filter has ample room around it's filter to create a viable heat sheild.. this UT thing looks like heatsoak waiting to happen, espectially with that heavy polished metal casing..
imho Popcharger or stock airbox for NA is probably the best route- just a suggestiong... you want to get the biggest velocity stack as possible, and the popcharger is the only one i've seen that has it. or retrofit the stock airbox with a wider smoother one that what it already has now.
Old Sep 1, 2006 | 05:52 AM
nator's z's Avatar
nator's z
Might I suggest the UTR carbon fiber intake tube with a popcharger. Looks great, otherwise, what Chebosto said.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
