Any Interest in NISMO style Exhaust?
Very well said. I just got home from doing the exhaust install. Easy setup and everything went on as it should however I am experiencing a little rubbing from the mid pipe but with more time and patience I am sure I can get it to where it needs to be, this is after all a bolt on kit and not slip fit. Must say the exhaust sounds great, barely noticeable at idle but really screams at full throttle. Tone is deeper then stock but not as loud as a v-8. No unbearable droning and seems to provide good flow. It kinda smelled bad when I got home but it is normal with a new exhaust. I was told that this would sound identical to the Nismo exhaust and I truly believe that it does. Ofcourse I have a s/c installed which enhances the tone and makes it slightly louder but still enjoyable on the street. On an N/A application I am sure it will be quieter and replicate that Nismo tone we all love. It got late so I didn't get a chance to snap some pics but ill get around to it sometime this week and let you guys know if I felt any changes from what I experienced today. Welds look great and SS appears to be of good quality so I don't expect this thing to fall apart anytime soon.
Thats not entirely true, if you copy the muffler size it will not be exactly the same. The internals of a muffler range significantly both in terms materials and flow design.
+1 on the pics - looking forward to seeing it.
Originally Posted by track04
this is just an exhaust guys. yes nismo did research to get it to what it is now, but since the work has already been done, as long as you coppy the bends, pipe size, and muffler size, it will provide EXACTLY THE SAME PERFROMANCE as nismo.
if the quality of the SS is not as good, then it wont last as long, but performance will be the same.
if they use good quality SS, then you are retarded to spend double on a nismo.
