coolant control valve
Old Sep 10, 2006 | 09:11 PM
JDM_ZED33's Avatar
JDM_ZED33
Default coolant control valve
was intsalling my 5/16" motordyne and it came with a coolant control valve.....dont know what it is, and if I need to install it...any ideas?
Old Sep 10, 2006 | 10:03 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
You don't have to install it, but its definitly better if you do. It will allow your plenum to run much cooler.
And since you live in SD, you can turn the valve to the off position and just leave it there all year round.
Old Sep 14, 2006 | 04:14 PM
JDM_ZED33's Avatar
JDM_ZED33
just installed it but wondering why would cutting off the coolant to the engine beneficial to the motor?
Old Sep 14, 2006 | 07:28 PM
Hydrazine's Avatar
Hydrazine
Its not coolant to the motor, its very hot coolant comming out of the motor that is being flowed through the plenum.
This is done to heat the plenum in the event of driving in really cold weather. This is to prevent ice formation on the throttle body butterfly valve.
Problem is, they heat the whole plenum in the process all year round. Even when it isn't needed.
The CCV allows you to not heat the plenum when the extra heat isn't needed. If you aren't driving in cold weather, you don't need your plenum to be heated.
Old Sep 15, 2006 | 09:33 AM
brigz's Avatar
brigz
I think i just might install mine now. I also had no clue how it actually worked.
Old Sep 18, 2006 | 12:28 PM
skyydiver's Avatar
skyydiver
Tony, are you not putting directions in your kits???
Old Sep 18, 2006 | 02:32 PM
masterj26's Avatar
masterj26
kit comes with directions and they are also on his website
Old Sep 18, 2006 | 03:47 PM
Hydrazine's Avatar
Hydrazine
Directions always go into the kits. They are a required part of the kit just as much as the actual product.
Other than the tools to put it in, the objective is to make each kit with everything needed for a complete installation.
Old Sep 25, 2006 | 11:51 AM
skyydiver's Avatar
skyydiver
Oh I Know this...I was just r***ing you.
Old Sep 25, 2006 | 02:41 PM
jondimellow's Avatar
jondimellow
tony-
i have the basic 5/16. i think the CCV is pretty cool idea, but i don't have one. can u just sell it to me seperately?
Old Sep 25, 2006 | 02:59 PM
rfinkle2's Avatar
rfinkle2
Could you guys tell me why ice would form on the butterfly?
I know it says that the ccv is used for climates usually above 45 degrees, but where would the water / condensation come from, and how would it freeze @ underhood temps??
-thanks
Old Sep 25, 2006 | 03:06 PM
undrgnd's Avatar
undrgnd
Ever heard of google or yahoo? Just put in "throttle plate icing" and you will have a few thousand hits... magic!
Old Sep 26, 2006 | 05:40 AM
rfinkle2's Avatar
rfinkle2
wow undrgrnd...thanks for the new sites i can check out. btw blow me
the sarcasm on this site is ridicolous.
my question was more at what temps the butterfly would freeze, but i guess i'll spend some time searching.
Old Sep 26, 2006 | 01:11 PM
jondimellow
Originally Posted by rfinkle2
btw blow me
haha
Old Sep 26, 2006 | 06:56 PM
Hydrazine's Avatar
Hydrazine
Originally Posted by jondimellow
tony-
You could install just a CCV, but you really want it with the Aramid gasket too. (You can find the Iso Thermal upgrade kit on our website.)
You need both the CCV and the Aramid gasket to really make a difference on the plenum temperature. There are 2 major heat inputs to the plenum.
1) Hot manifold heat transfer.
2) Hot engine coolant heat transfer.
The Aramid gasket cuts off the heat soak through the lower manifold.
The CCV cuts of the heat transfer from the hot engine coolant.
Think of it this way. The aluminum plenum assembly has the equivalent of two blow torches pumping heat into it. If you block the heat from one torch, the plenum will still be quite hot. But if you block the heat from both, it will make a big difference in assembly temperature.
This is why you need both the gasket and CCV for a real effect.
Old Sep 26, 2006 | 07:01 PM
Hydrazine's Avatar
Hydrazine
I use 45'F as the minimum temperature to turn on the CCV because it leaves a good (safe) margin above freezing.
Old Sep 27, 2006 | 07:37 AM
rfinkle2's Avatar
rfinkle2
thanks hydrazine... once the engine is warm, is it OK to close the valve again?
Old Sep 27, 2006 | 07:50 AM
Hydrazine's Avatar
Hydrazine
Valve position is adjusted based on atmospheric conditions.
Not engine temperature.
If it's freezing cold outside, turn the valve to the "open" position regardless of engine temperature.
OTOH, if you have the Copper Iso Thermal, you don't have to adjust anything. Its all automatic and it works even better than the CCV if you are driving in cold weather. The Copper allows you to heat the throttle body without having to heat the entire plenum. And this means you can take better advantage of the very cold air you are driving around in.
Cold air is great for the engine, just not the throttle body butterfly valve...
Old Sep 27, 2006 | 07:57 AM
rfinkle2's Avatar
rfinkle2
i was speaking of the manual valve style
Old Sep 27, 2006 | 01:11 PM
rfinkle2's Avatar
rfinkle2
thanks for the quick replies...you answered my question and i'll be ordering soon.
