LOOK! K&N/INJEN buyers SHOULD see this!
Old Mar 10, 2003 | 02:35 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
Originally posted by BullishZ
In the air fuel ratio, the higher number means higher air doesn't it? ie. leaner?
Because on both of your dyno stats, the blue line (which has the K&N) has the higher number of air fuel ratio.
sorry, you are right, i wasnt paying attention to the legend!!
now you got me thinking if their wide band lambda sensor is just fux0red?!? see.. both brad's and my A/F is exactly the same (blue:blue, red:red)... maybe just a calibration issue?
m
Old Mar 10, 2003 | 02:50 PM
BullishZ's Avatar
BullishZ
m
Pretty odd... I don't know what to make of it. Anyone an expert?
Old Mar 10, 2003 | 03:06 PM
Chebosto's Avatar
Chebosto
for the Air/Fuel ratio,
the closer the Line is to 10, the Richer the system is.
those Spikes in HP, correspond to a spike in a Lean A/F curve.., maybe that was a detonation fluke.. because your other runs seem to be quite smooth.
more air = leaner... this is the case with my run.. injen lets more air in than k&n
brads is the opposite... he got less air in, and it looked to run richer...
Old Mar 11, 2003 | 08:14 AM
BullishZ's Avatar
BullishZ
Thanks for the insight.
Old Mar 11, 2003 | 09:13 AM
z327's Avatar
z327
Has anyone tried the procedure in the service manual to "re-learn" the air fuel mixture. I've done the procedure but can't spend money on a dyno until after my new 5AT gets installed (started whining and shifting a little out of sync).
Old Mar 11, 2003 | 02:33 PM
azaz's Avatar
azaz
What is the procedure to "relearn" the ECU?
Old Mar 12, 2003 | 08:58 AM
christurismohk's Avatar
christurismohk
So, in conclusion, should we get the Fram filter?
Old Mar 12, 2003 | 09:39 AM
phreezee's Avatar
phreezee
In conclusion, the 350Z has a well-designed oem CAI.
Old Mar 12, 2003 | 10:15 AM
droideka's Avatar
droideka
No. The FRAM filter doesn't fit as tightly (just by a hair) as the OEM or K&N. I've actually put the OEM filter back in this week. At only $9 a pop I'll change it out monthly if I want.
I used the $7 FRAM to prove a very simple point. You don't always get what you pay for spending money on "performance" filters!
Old Mar 12, 2003 | 12:13 PM
Chebosto's Avatar
Chebosto
theory:
our stock fuel/air mapping is already lean(-er) than normal.
hypothesis:
due to the induction of a higher free flowing intake system, there is more cooler / denser air getting into the engine. thus creating an even leaner fuel curve. engine senses this, and retards ignition to prevent knocking.
data:
skidazzles zero gain w/ injen intake after running 300+ miles on it. other private dynos that have displayed little gains.
conclusion:
our hypothsis can not be proved just yet, with my ECU being dissected and changed, the research/results might yeild more conclusive answers at a later point ~2weeks after the car is dyno tuned and ignition/A-F changed from stock
any thoughts?
Old Mar 12, 2003 | 12:28 PM
BullishZ's Avatar
BullishZ
I just read an article on the air/fuel ratio on Tech Talk and the optimal air/fuel ratio for POWER is about 12.5 or so. At 14.7, fuel effiency is maximized...
Still, this does support the dyno sheets since the FRAM got the A/F ratio closer to 12.5 as compared to the K&N.
Old Mar 13, 2003 | 04:18 AM
VandyZ's Avatar
VandyZ
theory:
hypothesis:
data:
conclusion:
any thoughts?
Could not have thought it better myself! The computer will learn eventually . . . I think. But this is nonsense, cant wait to be able to know exactly what the ECU is doing. Even if we never really know I cant wait for us to be able to tell it how we want it to behave. With clever intake and exhaust mods and an ECU to compliment we may see 350hp at the crank.
Old Mar 15, 2003 | 08:52 AM
hfm's Avatar
hfm
Does all this simply mean we will not see the effects of a K&N or CAI until the Nismo ECU appears?
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
nanotech
Oct 2, 2015 05:02 AM
