Got my Evo2 installed finally, another question
Old Oct 12, 2006 | 02:32 PM
wren57's Avatar
wren57
Default Got my Evo2 installed finally, another question
Sounds great... I took it for a spin around the block, and 1/2 way through the trip all my dash lights went off and my radio quit working!!! WTF!?! Thankfully all my non-electrical gauges kept working (speedo, oil pressure, voltage), but I'm confused as hell... any thoughts would be awesome!
Old Oct 12, 2006 | 02:41 PM
350Zteve's Avatar
350Zteve
Did you check your fuses? Not sure how installing the exhaust could have blown one, but it sounds like a blown fuse. Did you remove the EVAP or just relocate it?
Old Oct 12, 2006 | 02:42 PM
wren57's Avatar
wren57
I just relocated it... took me like 2 days to figure out where the hidden bolt was, but I relocated it and hooked everything up just fine...
Old Oct 12, 2006 | 02:48 PM
VIZAGE's Avatar
VIZAGE
This might be another problem in itself. Did you install this yourself? There shouldn't of been anything electrical around the system. I had a problem with the EVAP system. That was mine fault due to hoses falling off. Hopefully it's a warrenty problem. You should here this system with headers and test pipes!
Old Oct 12, 2006 | 03:14 PM
wren57's Avatar
wren57
Strange... I'll leave this issue to tomorrow to look at as I'm tired of dealing with it right now... yes I did the install myself, and yes the EVAP relocate was a massive PITA due to that hidden bolt, but other than that it was smooth sailing. As far as warranty, I'm at 50k miles so it won't be covered. BTW, I have xerd long-tube headers and the exhaust is still *really on the quiet side, even as quiet as when I had stock exhaust on with the headers...
_koubie_
Sep 20, 2015 06:34 PM
OperatorAF
Sep 13, 2015 11:36 AM
