I Can't Decide! Help!
Old Oct 17, 2006 | 08:43 PM
btchnzcar's Avatar
btchnzcar
Default I Can't Decide! Help!
I just can't decide what I want to do right now with my limited funds. Here are my three options:
Nismo exhaust plus,
Option 1. High flow cats
Option 2. Resonated test pipes and Pop charger
Option 3. Pop charger and plenum spacer
Which option will give the most noticeable gains for now? Emissions are not a concern. I hear that test pipes give off a bad smell, but is it really that noticeable?
Any input is much appreciated!
Old Oct 17, 2006 | 09:00 PM
dragonbz99's Avatar
dragonbz99
i think test pipes gives around 9-10, spacer is 10-13. and pop charger is about 6? these are all separate, i don't know how they stack up.
Old Oct 17, 2006 | 09:56 PM
FrickU's Avatar
FrickU
If emissions aren't a problem, then definately go with the test pipes and pop charger setup. You can also get resonated test pipes as well. Good Luck with your decision.
Old Oct 18, 2006 | 12:44 AM
btchnzcar's Avatar
btchnzcar
If I plan on using N2O later on, does it matter if I use high flow cats or test pipes?
Old Oct 18, 2006 | 11:16 AM
Nismo350ZRT's Avatar
Nismo350ZRT
Option 2. The Nismo exhaust isn't going to do much with the cats restricting the exhaust flow.
Old Oct 18, 2006 | 11:33 AM
Ghost 350z's Avatar
Ghost 350z
if you want your exhaust to smell get test pipes, if not get HF cats
Old Oct 18, 2006 | 02:40 PM
Take it to jesus.
Old Oct 18, 2006 | 04:33 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Old Oct 18, 2006 | 04:38 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by HyperSprite
hyper you have the best sig evar ddddee
lapham3
Oct 7, 2022 03:15 PM
Justin100
Nov 25, 2021 06:26 AM
3vilbunny
Jul 18, 2017 05:10 PM
