error code 1168,
Old Nov 2, 2006 | 05:41 PM
DayBlueZ's Avatar
DayBlueZ
Default error code 1168,
closed loop control bank 2, what is this message and how do i fix it? Is it the O2 sensor in the test pipe on the passenger side? I got it after i put on my headers.
Old Nov 4, 2006 | 07:39 AM
m1james@bellsou's Avatar
m1james@bellsou
Z 1168 Diagnostic Code.doc
Here's what the manual says....good luck!
Old Nov 21, 2006 | 08:45 PM
DayBlueZ's Avatar
DayBlueZ
Ok i finally broke down and took out the O2 sensor. Turns out i somehow cut the line and severed the gray wire. I soldered it back together and all is well, no ses light.
Well, i dyno'd and corrected my AF ratio after the header install with this O2 in this condition.
Question is:
Will that bad sensor affect the AF or timing when tuning the UTEC? It should affect it in some way shouldn't it?
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
