question about spacer???
Old Nov 4, 2006 | 03:58 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default question about spacer???
i have an 06 enthusiast auto w/ 2,700 miles and planning to put plenum spacer, gains will be between 6-16 whp, now to get the gains will i need to have a reflash or will i get it without getting it. So far JWT pop charger is the only engine mod i have now.
Old Nov 4, 2006 | 05:30 PM
Gary King's Avatar
Gary King
If you have the revup engine I think you don't see much gains with a plenum spacer and should consider the MREV from Motordyne. Search around and there's lots of info about it. What ever you get though a reflash will not be needed.
Old Nov 4, 2006 | 05:49 PM
first350's Avatar
first350
The plenum spacer would still help - but like stated above it might not make the same HP/TQ gains on earlier models...AAM aslo has an angled plenum spacer and could do your relfash if you wanted. (The general rule is to wait for a reflash until you've done all of your power mods, other-wise you'll be spending extra $$ to reflash after every mod.)
plenum spacer:
http://www.alteredatmosphere.com/mm5...de=350Z_INTAKE
reflash:
http://www.alteredatmosphere.com/mm5...y_Code=350Z_EM
-Peter
Old Nov 4, 2006 | 07:14 PM
You have the revup motor. See the intake forum for recommendations.
Old Nov 5, 2006 | 07:36 AM
PythonLaX's Avatar
PythonLaX
Actually the 5AT does NOT have the rev-up motor. The gains will be the same as the other 287hp engines.
Old Nov 5, 2006 | 07:48 AM
PythonLaX's Avatar
PythonLaX
Oh and to answer your question: reflash after your done with all your breathing mods, otherwise you could end up wasting lots of money
Old Nov 5, 2006 | 04:16 PM
z-u-later's Avatar
z-u-later
If you have an A/T, all you need is the Motordyne 5/16" spacer. I highly recommend you order it with the ISO thermal kit.
issyz
Jul 2, 2017 03:04 PM
