Relocating evaporator for duals
Old Nov 8, 2006 | 06:29 PM
napier2's Avatar
napier2
Default Relocating evaporator for duals
Has anyone done this? and what is involed to do this what do I need to do.
I have my mufflers for duals and a shop to just do the back end for now, axle back with the 2 mufflers where the stock exits but the little black box of lines are in the way or seems to me they would be any way.
Old Nov 9, 2006 | 08:04 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
They shouldn't be in the way, unless your using larger than 5x9 mufflers. You will likely just have to remove the cover for it and put a little silver heat wrap on the closest hose for safety.
After all - the FI Intimidator exhaust is dual muffler setup in the rear, and you only have to do what I mentioned to make it work. Sound like they haven't designed it right....
Rick
Old Nov 9, 2006 | 12:53 PM
napier2's Avatar
napier2
Default Evap relocation
The stock exhaust is still there I was under the car looking and it looke close to me, thats all.
Thanks for the input
Old Nov 9, 2006 | 02:03 PM
MustGoFastR's Avatar
MustGoFastR
Yeah, I saw a DIY thread about a week ago where a guy replaced the canister altogether with a little PVC contraption; pretty slick job. Try to search it up.
Old Nov 9, 2006 | 08:34 PM
ISMSOLUTIONS
No problem...as long as they bend the pipes properly and angle the mufflers - you should have no problem at all...
Rick
Old Nov 10, 2006 | 12:02 AM
undrgnd's Avatar
undrgnd
The 1 1/2" PVC cylinder takes up almost no space, is much lighter and does not throw a CEL. It's definitely a DIY, and I never wrote up any instructions, but the hoses are routed just like the originals. Take out the cannister and stare at it a while next to the cylinder, you can figure it out.
Attached Thumbnails Relocating evaporator for duals-pict1097-large-.jpg   Relocating evaporator for duals-pict1104-large-.jpg   Relocating evaporator for duals-pict1105-large-.jpg
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Apr 28, 2017 09:00 PM
