Need help with Pulleys
Old Nov 28, 2006 | 04:20 PM
MFAnello350's Avatar
MFAnello350
Default Need help with Pulleys
Hey guys...
well i tried searching through threads and i couldnt find much...
maybe someone can help me out...
im looking to do a pulley upgrade...question is...whats the difference between KJR's and URs? i just want the most for the money...i know it wont make alot of power but i just want the better one of the 2....can someone help me out? i tried searching and i couldnt find what im looking for...help!!
Old Nov 28, 2006 | 04:48 PM
mikead_99's Avatar
mikead_99
Your search was bad......or the search feature sucks here.
The difference is the KJR is stock diameter, the UR underdrives a bit (smaller). Both are lightened crank pullies. There was a rash of manufacturing issues reported with the KJR. Some issues reported with UR too, but mostly do to improper install. The main issue with either is a bad crank seal, not something you want. Use at your own risk, like any other mod.
Old Nov 28, 2006 | 04:53 PM
MFAnello350
what should i do? is it worth the money? and if it is...what would you go with?
Old Nov 28, 2006 | 05:12 PM
mikead_99's Avatar
mikead_99
This is one mod that will almost certainly void warranty on anything to do with your engine I'm sure, but it does give a little better throttle response for very little $. I can't tell you if it is worth it for you, but I went with the UR.
Old Nov 28, 2006 | 05:17 PM
MFAnello350
did you go with the FULL set or just the Crank pulley?
Old Nov 28, 2006 | 05:25 PM
mikead_99's Avatar
mikead_99
Just the crank, the others only offer a bling factor, no performance benefit.
Old Nov 28, 2006 | 05:40 PM
MFAnello350
where did you get it from? from local shop or internet?
Old Nov 28, 2006 | 06:06 PM
I found 535 pulley posts in this forum complete with comparisons, critiques, how-to and precautions. Be a smart buyer. Read.
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
