Greddy manifolds CRACK
Old Dec 23, 2006 | 09:56 PM
tecni's Avatar
tecni
Default Greddy manifolds CRACK
Ok so I already had a manifold crack with only 8k mi. I hd it replaced by greddy and now I have the one on the opposite side crack as well.
Does anyone make a tubular manifold for this kit???
Cast iron sucks
Old Dec 24, 2006 | 04:25 AM
phunk's Avatar
phunk
CJ Motorsports
cast iron is the way to roll for reliability. i think greddy has had a problem with some core shift or something in their castings. they are aware of the problem, i am not sure if they made adjustments to their castings or not.
Old Dec 24, 2006 | 08:10 AM
tecni's Avatar
tecni
what do you mean "as far as reliability"?
I went to talk to Geo @ Titan when my manifold cracked and he was surprised it cracked at only 8k mi. He said they don't usually crack until 60k mi or so. So abviously its not strange that they crack.
I got a local shop that can fabricate them but I'm sure it will come with a heafty price.
Old Dec 24, 2006 | 09:08 AM
Zivman's Avatar
Zivman
Cast handles the heat cycles much better than any tubular manifold will. SS tubular are much more prone to cracking than a cast manifold is.
Old Dec 24, 2006 | 09:31 PM
tecni's Avatar
tecni
I'll take my chances with tubular.
Old Dec 25, 2006 | 04:38 AM
Zivman's Avatar
Zivman
Just don't think for a second, you are gaining any more "reliability" by going with a tubular setup.
Old Dec 25, 2006 | 11:08 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Exactly. "most" fabricated manifolds eventually crack. That said, if you use the BEST materials, and proper, certified welding techniques, they should not crack under any circumstances. The challenge is finding a fabricator that is skilled in this process, and that will stand behind his work. 8 gauge SS tubing, 1/2 inch SS flanges, meticulous preparation and fitting, back-gassing tig welds should hold up to anything you can throw at it.
Unfortunately, very few shops are any good at this. And quality fabrication and welding is expensive....as are the materials.
Which brings us right back to cast manifolds.
Unless I was building a custom turbo setup, I would stick to the out-of-the-box casting. You probably just got a bad batch, or maybe the studs were trqed a little funny.
Old Dec 25, 2006 | 05:41 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
or the car was tuned lean ^
Old Dec 25, 2006 | 06:17 PM
tecni's Avatar
tecni
nah, the car has never had a tune other than the one preinstalled in the emanage blue and the manifolds were torqued down to greddy's specifications.
Old Dec 25, 2006 | 06:42 PM
QuadCam's Avatar
QuadCam
if someoneis going to fab a tubular manifold, make sure they use a thick wall stainless or inconel tubing. there are a few places that sell schedule 10 SS tubing now.
Old Dec 25, 2006 | 07:44 PM
tecni's Avatar
tecni
Got any names of places that do?
Old Dec 25, 2006 | 10:02 PM
overZealous1's Avatar
overZealous1
you could find the tubing itself easily. but finding someone with the correct dies for a mandrel bender (and willing to do only a few bends) will be the tough part. inconel would be crazy expensive, and even tougher to find someone capable of welding it correctly.
the trick is making zero-gap fitments so you are welding the material together and adding filler, rather than using just filler to span the gap. then brace the turbo or manifold back to the block. back-gassing is good also, but you would spend crazy money to have someone do that on every weld on custom manifolds.
good luck which ever way ya go.
Old Jan 20, 2007 | 02:10 PM
QuadCam's Avatar
QuadCam
sorry, I haven't check this thread in awhile.
talk to vibrant performance. Titan is a dealer for them, I think. vibrant manufactures all kind of trick stuff.
Old Jan 20, 2007 | 02:12 PM
QuadCam's Avatar
QuadCam
the other place to look for exotic piping is www.burnsstainless.com while, in their website, take a look at their merge collectors! That is what a collector is supposed to look like!!!
Old Jan 20, 2007 | 02:54 PM
cnile51's Avatar
cnile51
call full race!
Old Jan 23, 2007 | 12:26 AM
tecni's Avatar
tecni
I checked all three sites you guys suggested. However, all of them seem to just facricate joints and such. I wish someone would just sell the manifold.
My car has been mysteriously overheating over the past few days and after checking the sparkplugs, I found that I have a tiny bit of coolant seeping into the cylinders so I'll be retorquing the heads tomorrow. If this doesn't fix the problem, I will have to replace the headgaskets and I'll possibly find both manifolds cracked due to hyper cooling from the coolant intursion. If this is the case, I'll probably have the shop fabricate new tubular manifolds. We'll see how it goes.
sales@czp
Sep 23, 2019 03:30 PM
Twenty4
Jan 17, 2016 01:20 PM
