Any news on the "dual intake" set-ups?
Old Jan 3, 2007 | 03:06 PM
Netko350Z's Avatar
Netko350Z
Default Any news on the "dual intake" set-ups?
I know that Crawford Z was trying to make one work. Anyone out there working on a set-uo like the one for the new VQ35HR series?
I can invision how the plenum would look....
There would have to be some stand alone to help with the increase in air into the motor to handle the lean #'s.
*edit*I know Cosworth was also working on one...$$$$$
Old Jan 3, 2007 | 03:25 PM
ACEMAN's Avatar
ACEMAN
Master
I have not seen or heard anything yet.
I guess Cosworth will be the first we will see.
Later
Todd
Old Jan 3, 2007 | 04:05 PM
Motormouth's Avatar
Motormouth
a tuner in Japan already has one running. I cannot remember thier name, but saw the car. did well in a test for just being tuned.
Old Jan 4, 2007 | 06:36 AM
Netko350Z's Avatar
Netko350Z
Anyone have any info on this one?
Old Jan 4, 2007 | 06:41 AM
blasian's Avatar
blasian
Thats the HR motor.
Old Jan 4, 2007 | 06:47 AM
Motormouth's Avatar
Motormouth
here is a link which provides pictures
http://www.jdm-option.com/eng/featur...2/z33_v35.html
Old Jan 4, 2007 | 09:45 AM
THE TECH's Avatar
THE TECH
I didn't think the Cosworth was dual intake.
Old Jan 4, 2007 | 09:48 AM
blasian's Avatar
blasian
Correct.
Old Jan 4, 2007 | 09:50 AM
97supratt's Avatar
97supratt
The cosworth piece is gonna be really really pricey. I'm not even sure its worth it because your paying over 1k dollars for a piece that won't add that much power. I would just save up for f/i.
Old Jan 4, 2007 | 10:03 AM
THE TECH's Avatar
THE TECH
I'm gonna jump on that Cosworth as soon as it's available.
Vader007's Avatar
Vader007
The Cosworth piece will not be that expensive for what you get, they are trying to keep it around $1000.00 for a complete manifold not just an upper plenum or a $300.00 metal shim! It comes with complete R&D from one of the most reputable shops in the world, not some local mom and pop metal shop/garage/tuner?installer/designer wanna be . (no insults intended here just explaining the difference between a world class organization and thet backyard builders/fabrictors) .
Its like trying to compare the Meagan coilovers with JIC Magic or HKS.
By the way I own the APS tall boy plenum and love it but will be selling that when the Cosworth comes out!
Old Jan 4, 2007 | 10:15 AM
rocks's Avatar
rocks
I want to know what this is.
http://www.webamuse.co.jp/new/products/cpu.html
Old Jan 4, 2007 | 10:44 AM
THE TECH's Avatar
THE TECH
Originally Posted by rocks
None of those ROM ECUs will work with our cars. Plus no one here can mess with them.
Old Jan 4, 2007 | 11:50 AM
IIQuickSilverII's Avatar
IIQuickSilverII
after looking at this the winner car has:
"The stock intake manifold' s capacity was increased by installing Esprit's intake spacer."
the Nismo car (2nd) has a stock aniversary edition manifold
the amuse car(3rd) has:Zenki Stock Intake Manifold which is basically a plenum with an added spacer onto it...
AND THE CAR with the dual intakes finished 12th?? not not saying its just related to it..there is much more to it..but people fail to realize that the winner car did not need this dual intakes to make it faster or more power there, may have to wait for development on the new vq to really see the improvements from it and if it can be addapted to the other vqs but its all long ways away... it surprises me how people just jump on things with out even looking or by just looking at the engine bay and seeing something shinny (which is how the ssv pos gained sales)
Old Jan 4, 2007 | 12:27 PM
Netko350Z's Avatar
Netko350Z
SPECIFICATIONS
·ENGINE & DRIVETRAIN
Nismo Spec 2 Head, Spec 2 Camshafts, Titanium Valves, 0.7mm Head Gasket, Forged Pistons, Connecting Rods, Crankshaft, Fuel Pump, Injectors / HKS PowerFlow / Custom Intake Pipes / Infiniti Q45 Throttle Body, Stock Intake Manifold with Esprit Spacer / Tomei Exhaust Manifold / Amuse R1 Titanium Muffler / ATS Carbon Twin Disk Clutch / Carbon LSD
Gotta get me a Q45 TB!!
Old Jan 4, 2007 | 12:28 PM
IIQuickSilverII
i dont this that is an expensive stock part but there still need some modifications to make it fit...
maybe someone can step up and make a kit out of this mod
Old Jan 4, 2007 | 12:29 PM
rocks's Avatar
rocks
Um japense spec ecu is the same as the US one thats why the techtom stuff works on it. You can buy the software technosquare and others use for like 3000$ if you really wanted to modify your own ecu.
Old Jan 4, 2007 | 01:03 PM
first350's Avatar
first350
interesting...they made it a dual intake, and compensated for the MAF (which would read 50% of the air coming in) by increasing the fuel injectors. They said it had just been finished...wonder how much HP they'd be able to get with a proper tune.
*How much can a reflash/Utec adjust MAF/Fuel maps? Would it be able to properly adjust for dual intakes and OR injectors?
-Peter
Old Jan 4, 2007 | 03:30 PM
ct350z's Avatar
ct350z
wooooooow, i just had an orgasm...
there are some sick a$$ z's there, that just makes me want to stick to the n/a route even more.
Old Jan 4, 2007 | 03:56 PM
ACEMAN's Avatar
ACEMAN
Master
Me too
But check out the FD on the Central20 car
while the 4.3 final gear ratio firmly keeps the powerband in check.
Big difference over the 3.9.
Good stuff one that read.
Later
Todd
