2007 z dual intake?
Old Jan 10, 2007 | 12:48 PM
clipso 01's Avatar
clipso 01
Default 2007 z dual intake?
If the dual intake makes significant power, do you think that we would be able to swap out our pleniums for the dual intakes. I am curious to see what the aftermarket does with this. Dual popchargers would be sweet. They would also look awsome in the engine bay.
anyone?
Old Jan 10, 2007 | 12:50 PM
savvy's Avatar
savvy
you are forgetting something much cooler than dual popchargers....dual turbonators
Old Jan 10, 2007 | 01:31 PM
clipso 01's Avatar
clipso 01
lol......quad, i want to put two in each
Old Jan 10, 2007 | 01:32 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You mean swap plenum and intake from a 2007 Z onto a 2003?
It's not going to be worth it. You heard it here first.
There is quite a bit of crap in the way, not the least of which is the power steering fluid resevoir...
Also, the VQ35HR plenum is most likely designed to make peak torque higher than even the rev-up motor. You will probably suffer if you put it on your non-revup.
Old Jan 10, 2007 | 01:34 PM
ESPO 774's Avatar
ESPO 774
what about putting it on an 06?
Old Jan 10, 2007 | 01:38 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
No possibility of that. They are not interchangeable.
A whole new plenum assembly will be needed if the 07 is to be modified.
Old Jan 10, 2007 | 01:40 PM
rocks's Avatar
rocks
For a 6hp total increase over the 2006, why would you even bother when they used that and other things such as new exhaust manifolds, ecu tuning, compression. Its not even worth it just to say you have dual intakes. If your worried about it go to a standalone and a giant throttle body.
Old Jan 10, 2007 | 01:43 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
But didn't SAE come out with a new standard for horsepower measurements this year?
For example, the BMW 335i which is measured at 300hp, is dynoing high 270's, low 280's whp bone stock (dyno jet)
I could be wrong about this.
Old Jan 10, 2007 | 01:52 PM
Steve-O Z33's Avatar
Steve-O Z33
Even if they were interchangeable, it'd cost quite a bit. Cosworth plenum FTW!
rocks's Avatar
rocks
SAE did come out with a new standard. Not all companies are using it yet. There is no telling if nissan is or not. Here is some information on it. http://www.detnews.com/2005/autosins...A01-283759.htm
Most cars are putting out lower numbers with it though.
Old Jan 10, 2007 | 01:55 PM
Cannysage's Avatar
Cannysage
I hope I see some, really high plenums and spacers in the future to utilize that new hood. I would like to see some aftermarket hoods with scoops as well.
Old Jan 11, 2007 | 06:42 AM
clipso 01's Avatar
clipso 01
Thanks for the info wired 24/7
Old Jan 11, 2007 | 07:51 PM
Hydrazine's Avatar
Hydrazine
I thought they would have released it by now. They apparently have already built prototypes and tested the gains.
I'm wondering if they are holding off on prodution to make a design compatible with the new engine. ...But the HR will require a 2nd design anyways?
I can't figure out what the hold up is.
Old Jan 12, 2007 | 06:49 PM
Quamen's Avatar
Quamen
I also believe that the 2007 intake will have square intake runners as the heads do which means that you would need to get your heads port matched also.
Old Jan 13, 2007 | 08:29 AM
Chineseguy's Avatar
Chineseguy
Dual Intake = Dual Popcharger = Double the money. SINGLE FTW!!!
Old Jan 13, 2007 | 08:38 AM
michaeljr6's Avatar
michaeljr6
damn......you have to get 2 tornado thingys now lol for better mpg
Old Jan 13, 2007 | 09:34 AM
dTor's Avatar
dTor
Yeah, there were a bunch of Honda Civic guys pissed about this. LOL
"OMG, it's supposed to have 200, but now it's only 197!!"
Like a Civic would really get 200 crank hp stock.
Old Jan 14, 2007 | 10:55 PM
Armitage's Avatar
Armitage
Actually most domestics are rating higher with the new standards, with most Euro's or Jap cars the same or lower. And I'm pretty sure this was done across the board. The new 306hp is supposedly around 315hp on the old setup I thought.
To the OP, considering the new VQ35HR is 80% from the 2006 motor, I don't think its as simple as a straight swap.
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
