O2 Sensor Heater
Old Jan 16, 2007 | 09:19 AM
zachcrosen's Avatar
zachcrosen
Default O2 Sensor Heater
I got a SES a few weeks ago and had the code pulled at Autozone. The code said it was a "low voltage to the O2 sensor heater". Anyone else have this problem?
Old Jan 16, 2007 | 09:21 AM
blasian's Avatar
blasian
I think thats the PO057 code.
I replaced my O2 sensors and it went away.
Old Jan 16, 2007 | 02:55 PM
zachcrosen's Avatar
zachcrosen
How much are the O2 sensors? I dont want to replace all O2 sensors if only 1 is causing the SES.
Old Jan 16, 2007 | 05:21 PM
rlwjr1's Avatar
rlwjr1
Just type the code into Google. You are almost guaranteed to get some sort of diagnostic type trouble tree.
Old Jan 16, 2007 | 09:14 PM
DayBlueZ's Avatar
DayBlueZ
Zach, they run about 110.00 yankee dollars from the factory, if you are handy with a solder gun, buy a 4 wire o2 sensor from auto zone, snip and rewire it. Tell em it's for the z and they will give you the right one. Has to be 4 wire. i just rewired mine a couple weeks back, and have the tools to get it done if you need em.
Old Jan 17, 2007 | 04:47 AM
zachcrosen's Avatar
zachcrosen
I need to figure out which O2 sensor is the bad one and go from there. I may look you up Larry.
Old Jan 17, 2007 | 04:52 AM
Theatrix's Avatar
Theatrix
Professional
When I had my code read, the guy was able to tell me exactly which o2 sensor was bad based on the code!
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350Z Project X
Oct 17, 2015 05:16 PM
