Kinetix SSV plenum questions
Old Jan 24, 2007 | 02:56 PM
ke0ki2k's Avatar
ke0ki2k
Default Kinetix SSV plenum questions
i have an 06' with the Revup...i was looking at the Kinetix SSV plenums...the radically different stainless ones yanno? & the dyno showed it increasing from 223 whp to like 239...which means it must have been an older model Z cause 06's dyno at like...250 or so stock correct? so does anyone know if the SSV even works with the revup? and if it does will it create the same results?
Old Jan 24, 2007 | 03:00 PM
Nic@CiNcity's Avatar
Nic@CiNcity
If you even tried to search this topic AT ALL, you would have seen this phrase used a bunch. "Don't waste your money".
I have to agree with it. I HAD one. Unless your going for the bling factor on a show car? As for using it on a revup, i don't see why it wouldn't, but don't quote me on that.
Old Jan 24, 2007 | 03:07 PM
If you have the money for the Kinetix SSV plenum, do a before and after dyno. It would be interesting to see the results on a rev-up motor after a tune. Someone has to be the first to give it a try right.
Old Jan 24, 2007 | 04:00 PM
VIZAGE's Avatar
VIZAGE
One day I want to take my SSV and add an direct port nitrous. After built motor of couse. I think it might be the only manifold you could do this with. I might be wrong though. But you can't say it wouldn't be one tight setup.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
