MAF Sensor on Popcharger
Old Feb 5, 2007 | 06:24 AM
DJMatrix1067's Avatar
DJMatrix1067
Default MAF Sensor on Popcharger
So, I took my car in to have my cathodes rewired at circuit city and everything was hunky dory. then i get my car back, start it up to roll out of the garge and my service engine soon light was illuminated.
went to autozone immediately to get the code scanned, and it returned a code that said something was wrong with the MAF sensor.
now nothing has changed in the car since i took it to circuit city. so i drove home, and popped the hood to look around and see if anything was weird looking, and i noticed that the two screws holding in the air sensor on my intake tube were loose. is this the MAF sensor? if not does it matter that those screws were loose.
i tried tightening down the screws but the service engine soon light was still on when i restarted my car. if i reset my ECU will it go away? what should i do?
Old Feb 5, 2007 | 07:13 AM
drap660's Avatar
drap660
That is the MAF sensor... The loose screws might have setoff the CEL... Try cleaning your MAF, retighten everything and get the code cleared by the scanner at autozone... its free.. You can also buy a scanner like I did for 70 bucks and always be able to check your codes and clear your CEL's
Old Feb 5, 2007 | 08:25 AM
THE TECH's Avatar
THE TECH
Old Feb 5, 2007 | 08:29 AM
playa6tnine's Avatar
playa6tnine
where did you get this, and how does it work?
Old Feb 5, 2007 | 08:35 AM
DJMatrix1067
so what's the best way to clean the sensor
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
