Best exhaust setup
Old Feb 14, 2007 | 12:33 PM
NISMO_558's Avatar
NISMO_558
Default Best exhaust setup
As of now I have crawford headers on the way, and AAM test pipes. I'm curious if those two components alone are better than replacing the entire exhaust, would keeping the stock cat-back in place give me better performance or would adding a cat-back with the headers and tp's give me the most power? I was looking towards borla true dual.
Old Feb 14, 2007 | 12:48 PM
saberphx's Avatar
saberphx
Depends. TPs and headers will most deffinatly make your car louder and meaner sounding. I would keep stock cat back untill you hear what its like. A cat-back for a non-FI car won't get you much more HP if any (especially without a dyno tune) All a catback will do is change the sound, make it louder, and looks better. Up to you there, chief.
Old Feb 14, 2007 | 01:00 PM
kwiker's Avatar
kwiker
Shift_Dorifto
Get the non-resonated JIC single and just drive down your street on the rev limiter.
Seriously...i like the HKS but don't have the money, it is quiet when driving around like a normal person and opens up when you get on it.
Old Feb 14, 2007 | 01:11 PM
Nerek's Avatar
Nerek
im debating between the HKS knock off and the topspeed pro N1...cant make up my mind..
any other exhausts for fairly cheap?im looking for some other mods so i really dont want to pay 12-1400 for the HKS
Old Feb 15, 2007 | 08:26 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Typically - you should do exhaust from the rear of the car forward, not the front back. Feeing up flow at the front, without modifying the back will hurt performance overall - in some combination. Pulse scavenging will be hampered, as the system will not handle the extra flow very well.
With that said - many people do it this way. For sound purposes, not an overall power plan for the car. The top 3 true duals are only a matter of 3-5 HP apart from each other, but have dramatically different sound between them. HKS, Stillen and Fast Intentions. The Fast Intentions and Stillen use 2 1/2" pipe - where the HKS uses 2 1/4" pipe. If your going to open flow even more, by adding headers and cats, the 2 1/2" systems are what you will want - unless you go with a 3" single with great Y-pipe.
Rick
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
