What are the signs??
Old Feb 21, 2007 | 05:33 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default What are the signs??
What are the signs of plenum spacer air leak??
Old Feb 21, 2007 | 06:54 PM
Black_Sunshine's Avatar
Black_Sunshine
A hissing sound, erratic idle perhaps. You can check for a leak with propane. Run the propane around the perimeter of the plenum. If the engine speeds up, you've found a leak.
Old Feb 21, 2007 | 08:20 PM
driftk1d's Avatar
driftk1d
is that safe? lol
Old Feb 23, 2007 | 04:38 PM
Ilov350ZEE's Avatar
Ilov350ZEE
is it ok for me to do this, put silicone sealant around each bolts and around the plenum? I think i may have a leak.
Old Feb 23, 2007 | 04:41 PM
SpoilsofWar's Avatar
SpoilsofWar
Thats putting a bandaid on a sucking chest wound. Take it apart and find the reason for your leak.
Old Feb 23, 2007 | 04:56 PM
Ilov350ZEE's Avatar
Ilov350ZEE
i didnt install it, I just notice this now when decelleration at almost stop the rpm will drop to 1k rpm then goes up 1,200 rpm then back to 1k rpm then goes down slowly at idle rpm thats w/o stepping on the gas just brake until the car gets fully stopped. Im not sure if i have a leak, the rpm stays steady in place when idle at 750 rpm.
Workshop12
Mar 23, 2020 01:45 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
