need help with stock upper plenum
Old Feb 23, 2007 | 01:57 PM
orangeZ89's Avatar
orangeZ89
Default need help with stock upper plenum
i need help with the torque setting on the bolts for the upper plenum. ive tried searching and cant find anything
thank you
Old Feb 23, 2007 | 03:50 PM
halfass872's Avatar
halfass872
I wish i could remember the link, but there is a website where you can download the entire factory service manual for free. Tells you everything!! If i wasn't at work right now i could find out for you. Don't quote me, but i'm pretty sure it's barely anything. Like 10ft lbs at the very most! And remember to at least go at a star pattern, although i know there is a specific order too for that. Sorry i can't be of more help
Old Feb 23, 2007 | 03:54 PM
Jay'Z's Avatar
Jay'Z
Use star pattern and tighten with one hand until you cant tighten anymore.. That is the spec..........
Do not use two hands..
Old Feb 23, 2007 | 03:59 PM
halfass872's Avatar
halfass872
Just to add to what jonb7007 said. Tighten with one hand with a nut driver. Do not use a ratchet or you'll over tighten and prob strip the threads.
Old Feb 23, 2007 | 04:52 PM
booger's Avatar
booger
you actually will snap the bolt before stripping the threads . Done it several times trying to fix a leak
Old Feb 24, 2007 | 03:36 AM
As per the spacer instruction from Motordyne:
6 bolts in center of plenum: 60 inch pounds
12 bolts on outer edge of plenum: 100 inch pounds
Old Feb 26, 2007 | 04:55 PM
Youre welcome.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
