HELP! Lower plenum is STUCK
Old Mar 18, 2007 | 10:59 AM
hiz-n-herz's Avatar
hiz-n-herz
Default HELP! Lower plenum is STUCK
I am trading in my 06 for an 07 and I am in the process of removing my MREV2 and spacer to install on my wife's 06 Z.
Well, I had the ISO-Thermal kit and the stupid Aramid gasket has basically glued the lower plenum to the intake manifold/block. it will not budge!
How hard can I beat on it with a rubber mallet before it breaks?
Any suggestions?
Thanks!
Old Mar 18, 2007 | 11:07 AM
hiz-n-herz's Avatar
hiz-n-herz
HA HA HA! nevermind....
I got pissed and WHACKED it hard with a rubber mallet... hahahaha ID didn't argue much more... It's off now...
Old Mar 18, 2007 | 11:09 AM
Nic@CiNcity's Avatar
Nic@CiNcity
Try giving it little love taps from all directions to free it up. Top, sides, under if you can? Stupid question, but i have to ask, are you sure you removed ALL the bolts first?? I can't emagine you'd hurt anything if its just the gasket holding it down. Maybe try some tiny amounts of gasket remover? But if you do, MAKE SURE you don't get that stuff on/in anything else. Powerfull stuff.
Nic@CiNcity
Ok then.. Congrats i guess?
Old Mar 18, 2007 | 12:04 PM
Cannysage's Avatar
Cannysage
getting pissed always did the job for me
Old Aug 4, 2017 | 01:42 PM
G35First's Avatar
G35First
Default Also stuck
I was puzzled for a bit as the lower plenum was stuck with the isothermal gasket. Thought the guidepins had to be removed but no. Light taps here and there broke it free.
I threw a towel on the bolt of the metal bracket, left side where the pcv tube nipple is. Plastic mallet broke it free in 2 taps at that bolt.
May 30, 2017 03:28 PM
James1990
Dec 16, 2015 08:57 PM
