Kinetix V+ or Motordyne 5/16" Isothermal??
Old Mar 29, 2007 | 05:55 PM
TommyP's Avatar
TommyP
Default Kinetix V+ or Motordyne 5/16" Isothermal??
Looking for input on which would be more beneficial. I want the setup to fit under the stock strut bar and hood, and I'm told you can go with either or, but not both. Does the Kinetix flow that much more and stay that much cooler than the stock pleum with the motordyne isothermal 5/16" spacer? I was about sold on the MREV2 + spacer deal, but for another $50 I can just get the new Kinetix on top of the MREV2... Suggestions? Comments? Problems?
Old Mar 29, 2007 | 06:06 PM
Reyes5937's Avatar
Reyes5937
I have the Kinetix V+ with MRev 2 and I love it. Besides Kinetix keeps your air temp. down. +1 on Kinetix and MRev 2.
Old Mar 29, 2007 | 07:01 PM
TommyP's Avatar
TommyP
word. the install pretty easy? everything fit up fine as far as the strut bar and engine cover going back into place?
anyone else?
Old Mar 29, 2007 | 07:04 PM
KelekonaKustoms's Avatar
KelekonaKustoms
install is pretty simple, just follow the instructions and torque everything down properly and your good to go
Old Mar 29, 2007 | 08:15 PM
TommyP's Avatar
TommyP
so the general concensous is that the mrev2 + kinetix > mrev2 + 5/16 spacer. got it...thanks
Old Mar 29, 2007 | 08:20 PM
Mike Wazowski's Avatar
Mike Wazowski
1 person answering isn't a general concensous LOL
IMO Motordyne is a better product. Kinetix from what I have seen and was foolish enough to buy in the past is pretty much garage garbage.
Old Mar 29, 2007 | 08:37 PM
TommyP's Avatar
TommyP
haha it was the general concensous so far
so should i not buy the fact that the new Kinetix V+ is "new and improved"? it's supposed to withstand 15psi, which eventually the car should see boost...i dont know about 15psi, but ya...
Old Mar 29, 2007 | 08:40 PM
AboostedG's Avatar
AboostedG
Twin Spoolin
As long as it's not the SSV, the Kinetix products are fine.
Old Mar 30, 2007 | 06:09 AM
Armitage's Avatar
Armitage
Isn't the SSV bad for N/A apps?
Old Mar 30, 2007 | 06:18 AM
TommyP's Avatar
TommyP
i'm n/a...just considering the V+
Old Mar 30, 2007 | 07:03 AM
Mike Wazowski
the SSV is just bad period. It is for bling only. No TRUE solid gains have ever been shown with it. Just inflated dynos.
Old Mar 30, 2007 | 08:36 AM
Reality350's Avatar
Reality350
Why not go with a proven setup? ie: MREV2+MD 5/16th spacer???
Old Apr 2, 2007 | 09:36 AM
six3mike's Avatar
six3mike
I was wondering the same thing.
Old Jul 22, 2007 | 03:58 AM
guigui79's Avatar
guigui79
from the profit point of view of of power and performance, which of both and best ?
kinetix V+ or spacer thermal Iso 5/16 ?
I have to find that, but it is with the kinetix V4.
Old Jul 22, 2007 | 05:19 AM
HondaKiller's Avatar
HondaKiller
If your getting the MREV then i suggest not mix matching it and getting the ISO spacer to along with it. Without a doubt, the Kinetix looks better than the stock upper collector, but why take a gamble on performance? The ISO spacer is PROVEN to lower plenum temperatures (especially with the addittion of the CCV valve) and GAURANTEE's HP gains. Kinetix claims HP gains, with a whole forum of people bashing their image for a reason. hundreds of people dont pull things out of their ***, so do your research and you'll see the Motordyne products are the safest most secure way to adding HP through your plenum. Good luck with your decision. +1 Motordyne
Old Jul 22, 2007 | 06:35 AM
guigui79's Avatar
guigui79
ok. thank you. it is true that there is no proof on the increase of HP on the kinetix V+, contrary in Motordyne spacer.
Old Jul 22, 2007 | 08:21 AM
guigui79's Avatar
guigui79
I will buy Motordyne spacer 5/16 " Iso thermal cooper. like that, not of tap…
Old Aug 25, 2007 | 12:19 PM
BCs350z's Avatar
BCs350z
not to hijack this thread but i was thinking about getting the MREV2. i already have the kinetix v+ plenum. is it really worth it to sell the kinetix V+ for a spacer?
Old Aug 25, 2007 | 08:51 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Not necessarily. The V+ gains will be close enough to the basic 5/16" spacer.
You may be able to do a little better with a 5/16" spacer but it may not be worth the time or effort of ditching what you have and buying a whole new spacer setup. ...So keep what you currently have (unless you don't care about the time or cost associated with ditching your V+).
OTOH if you have a REVUP engine, I definetly recommend adding the MREV2 to it.
On a REVUP engine the first plenum mod to get is the MREV2 and then add what ever upper plenum mod/spacer you want. Spacers and upper plenum mods don't do jack on a stock REVUP lower plenum. ...But they do work on a MREV2.
NissanZcrazy
Sep 23, 2015 07:59 AM
zcoupe
Mar 30, 2009 05:19 PM
dingobiatch
Jul 28, 2006 03:49 PM
