Plenum Help!!!
Old Apr 25, 2007 | 10:05 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
here is a pic of the little tube right before it was sent, it's straight down, you should also post up the pics of the all the protective plastic it was wrapped in, and of the box. it had to be done by the shipping, the only way to ship to HI is by air in which it was next day so im sure they werent real gentle w/it. I have tried to bend over backwards to help you out. and had this sold to other people that i wouldnt have had to go through all the shipping bs, and have a core. so for you to try an act like i havent tried to help the situation is not cool. I shuld have never even bothered sending this to you in HI since your avatar oringinally stated Nashville TN???
sluggoZ's Avatar
sluggoZ
Originally Posted by BlueDragonZ
I'm trying to get it worked out with the seller right now. It wasn't the shipping because the box that it came in was fitted just enough for the plenum to go in with the bent tubes. After I bent the large tube back the way it's suppose to, I can't get it back in the box. Plus the way it was wraped leads me to believe it was already bent when it was placed in the box. Can't return because I'm in HI so I would loose a whole lot more money. I just hope that this person will do what's right.
Geez...you should be able to send it back!!! Sounds to me...it wasn't right in the first place. Good Luck!
BTW Do what you have to do with your vendor first...if not satisfied, I would bring out your complaint in the open forum discussion again.
Old Apr 25, 2007 | 10:10 AM
ARMSTRONGARMS
What do you expect me to do anyway???? The last pm from you which was weeks ago, i was under the assumption the issue was resolved? before you posted the last few statements you prolly should have pm'd me! I didnt even know about this thread until after all the pm's i sent you trying to help resolve this.
Old Apr 25, 2007 | 11:02 AM
VO...'s Avatar
VO...
Administrator
It doesn't look like he was trying to call you out, just trying to get a fix for his situation....
Old Apr 25, 2007 | 11:12 AM
ARMSTRONGARMS
It has been several weeks??? since ive heard anymore about this, i thought it was taking care of. I know for sure the tubes were not bent before shipment. I have suggested that he contact the shipping co about this, but seeing how long it has been, i dont know what they'll do. As for calling me out, that's is how i took it, he posted the above statements and i havent recieved any pm's or such from him? dont you think it would be appropriate to contact me first, especially since it's been several weeks since the last pm's w/him in which i thought everything was taken care of.
Old Apr 25, 2007 | 11:14 AM
ARMSTRONGARMS
NO i just got a email from him where he said he had to purchase a copper theremal bypass from tony for 70 dollars, and feels i should pay for all of it?
Old Apr 25, 2007 | 11:18 AM
ARMSTRONGARMS
you can see in the pic above the little tube is straight down like it should be, that was taken right before it was packaged with about a 1/4 of protective plastic wrapped around it? this would really be a shipping issue, and i feel he should try to go through them, as i have no control of this once it leaves my hands, that's why i wanted him to post pics of the box and all the protection it had? it was packaged well, but if they laid something real heavy on it thing i guess it could have bent the rods, and w/the amount of plastic i put around the plenum doubt it would puncture the box. Im willing to bet they stacked items on top of it. please check w/the shippers and see what they wil do.
Old Apr 25, 2007 | 11:25 AM
VO...'s Avatar
VO...
Administrator
We didn't know that he had not PM'd you yet. I probably would have.
VO(wishes the best outcome for everyone)
Old Apr 25, 2007 | 11:32 AM
Eazzy's Avatar
Eazzy
Originally Posted by Hydrazine
Now you need to get the "Copper" Iso Thermal upgrade.
Thats the way to go ---Actully those are pressed in and though a tight press are removable. I would have extracted them and fabbed new ons and in most cases I have things laying around that would have worked fine.
If in a situation like that, you end up with a medium press, Red Loc-Tite will do the trick or if a Light/somewhat loose/very loose press then JB would have been fine. And Devcon makes all sorts of products ( epoxy )
Old Apr 27, 2007 | 08:15 AM
ARMSTRONGARMS
Well i figured he'd post in here again? anyway he contacted the shipping co. and we have to fill out a claim, then they will come inspect the packaging and damage. Hopefully they'll take care of this as i know for sure it was damage due to shipping. I'm actually very surprised they were willing to do anything since it's been about a month
Old Apr 27, 2007 | 09:09 AM
sluggoZ's Avatar
sluggoZ
That's good! BTW just yesterday I received my rear deck wing that I ordered...came from the state of Washington via ups.....the box looked like it went right through the war zone....just crushed at all corners with loose tape ends....remarkably the wing was Ok..is was wrapped in bubble wrap. I should of taken a pic of the box before I opened it but I didn't.
Good Luck guys!
Old Apr 27, 2007 | 03:23 PM
BlueDragonZ's Avatar
BlueDragonZ
Just for the record I didn't start this thread to bash Adam (idwin) but to simply get some help. Like I said earlier in here I was trying to get it worked out. That's basically where we are at this point. I'm filling a claim through DHL right now for the damaged piece. When I first recieved the item and it was bent, with Adam's help I thought I was going to be able to fix it. Reason why there was such a lag when I first got until now. I actually tried to fix the thing with JB Weld. I contacted the manufacturer to see if will in fact work but didn't get a response, so I tried it anyway. I thought it was going to hold so that's where I left it with Adam.
Fast forward to when I actually had a chance to re-install it 04/23, nope it didn't hold. So, I emailed Adam trying to get it worked out since I have to shell out 60 bucks for Tony's piece. I know that Adam has a good little business going on here that's why I didn't post who I got it from because I'm sure it's an isolated incident. Unfortunately this thread got taken out of context. So, just to clear the air I don't have any problems with Adam (idwin) he is trying to help me get this resolved from Day 1 until now.
As far as the plenum is concerned, it's a great product. I can't wait to get the piece from Tony and get this installed on my Z. As a matter of fact, Adam aren't you doing pop charger shields and strut bars too? Hmmm might need to get those from you too.
Old Apr 30, 2007 | 07:36 AM
ARMSTRONGARMS
did you get the form from dhl?
Old Apr 30, 2007 | 02:06 PM
BlueDragonZ
Yes but please check your email because I've advised you of that on Friday.
Old May 1, 2007 | 12:02 AM
ARMSTRONGARMS
what i meant to say is did you hear back from them yet, since filing the form
Old May 1, 2007 | 12:24 AM
BlueDragonZ
waiting patiently
Old May 1, 2007 | 09:41 AM
VO...'s Avatar
VO...
Administrator
Does DHL require the shipped item to be insured, in order to file a claim?
Old May 1, 2007 | 09:53 AM
  #38
ARMSTRONGARMS
it was insured for 100, and seeing the part is going to cost 60? dhl seems to be handling this as of now.
Old May 1, 2007 | 10:04 AM
  #39
Eazzy's Avatar
Eazzy
Iv started using DHL with good luck, they seem a little disorganized but it works
On their forms they say
Absent a higher shippment valuation,carriers liability is limited to 100.00 per shippment, or actual value,whichever is less.
Special or consequential damages are not recoverable
Then goes on to say in fine print:
Claims must be submitted within 9 months etc etc----andWritten notice of concealed damage or loss must be given to DHL within 15 days of delivery
Old May 1, 2007 | 10:38 AM
  #40
ARMSTRONGARMS
ive used dhl for a long time, this is the first time ive had a incident w/them? hopefully they'll man up as i know for a fact it was their mishandling that led to the damage.
