stupid test pipe nut
Old Apr 9, 2007 | 10:59 PM
jaida86's Avatar
jaida86
Default stupid test pipe nut
so i was curious, the one nut that would be more easily accessed from the engine bay, did you use a very long extension or did you just jam your hand on in there.
if so on the extension, can someone recommend a length
thanks in advance
Old Apr 10, 2007 | 06:11 AM
jehamilton_98's Avatar
jehamilton_98
Actually I just shoved my hand in there (I have small hands) and came out with these really cool bloody knuckels. It worked tho.
A photo is worth a thousand words.
The header to test pipe connection? A open ended wrench works well. Helps to have skinny hands.
Old Apr 10, 2007 | 08:09 AM
jaida86's Avatar
jaida86
yeah ill try and get a pic today... but if your looking down into the engine bay the top nut of the triangle is the one i cant get off. i can get to hit but i dont have alot of room to work with a tool in there. has anyone ever used a very long extension to do this?
Old Apr 10, 2007 | 08:12 AM
genegoesfast's Avatar
genegoesfast
I used about three extensions connected to one another. you need about 2.5-3ft. good luck.
Old Apr 10, 2007 | 08:17 AM
jaida86's Avatar
jaida86
thanks thats exactly what i needed to know!
Old Apr 10, 2007 | 08:40 AM
MUZZY's Avatar
MUZZY
i used 3 extensions also
Old Apr 10, 2007 | 08:59 AM
HondaKiller's Avatar
HondaKiller
i used 2 extensions probably a foot and a half long. It was a knuckle buster and make sure your engine is totally cooled. You can get it done, it is just a little teatess.
Old Apr 10, 2007 | 09:45 AM
jaida86's Avatar
jaida86
awsome thanks for all of the info guys!
Old Apr 10, 2007 | 10:37 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
+1 ... the top bolts are more easily accessed using long extensions. The bottom bolts are more easily accessed using a small wrench and jamming your hand up there
Old Apr 11, 2007 | 11:33 AM
350Z_GTS's Avatar
350Z_GTS
It is a pain in the butt, i think i had 5-6 small extensions since i had no long ones. That along with a flex joint socket helped a huge amount. Good luck
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
