Injen TD angled Install questions
Old Apr 14, 2007 | 12:13 PM
drewb612's Avatar
drewb612
Default Injen TD angled Install questions
I bought a used Injen angled TD and assuming nothing come with it as far as hardware, i was wondering what i needed as far as gaskets are concerned or other hardware. I currently have 30k on my stock exhaust and im not even sure if the gaskets will fit/or are still good. Thanks!
Old Apr 14, 2007 | 12:29 PM
For a quality job, use new gaskets. The Injen comes in 6 pieces, so you need 6 standard 2-bolt gaskets. OEM gaskets should be OK. About $30 from Nissan. Or make a pencil and paper rub of one of the fittings, and take it to an auto parts store. I also recommend quality stainless steel hardware.
Old Apr 14, 2007 | 12:44 PM
drewb612's Avatar
drewb612
so the gaskets are like 5$ a piece? Are they the all the same size including where it bolts up to the cats? Also what parts are you referring to as "stainless hardware"
Old Apr 14, 2007 | 12:51 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Gaskets are about $30 a pair from a nissan dealer, if you buy from an auto parts store and match the size up as davidv suggested, you may find them for less.
I think by hardware he means nuts and bolts.
Old Apr 14, 2007 | 01:58 PM
Its a 2-bolt gasket. Whether the inner diameter is 50, 60 or 70 mm, the distance between the center of the bolts is the same. You have all the pieces right? Measure them to make sure that I am correct.
Hardware is nuts and bolts.
Old Apr 14, 2007 | 02:00 PM
BTW did you get this brace?
Old Apr 14, 2007 | 06:07 PM
drewb612's Avatar
drewb612
no it does not have that brace. However it does have a welded X-pipe so that sturdys it up a bit.
aarrgghh
May 1, 2022 11:04 AM
Workshop12
Mar 23, 2020 01:45 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
