Can it be? Happy with NA mods
Old Apr 22, 2007 | 08:31 AM
teacher's Avatar
teacher
Default Can it be? Happy with NA mods
This is a (nearly) unbiased review of what various parts have done for my 03` 350Z. I place it here because the JIC ti single is the latest, and perhaps best mod I`ve done.
Mods: (in chrono. order)
-Track rims
-+2 timing w/ Consult
-PC680 battery
-UR flywheel
-spare/jack weight reduction
-5/16`` spacer
- pop charger
-JIC full Ti.
*No tune, but several battery disconnects/jumps
Even after the spacer and popcharger I noticed only a minimal change in the character of the car`s powerband. I won`t attempt to assume a human dyno readout at this point. After some miles with the exhaust, however, the car has a distinctly stronger pull to redline. I don`t feel any notable loss in torque either. I`ve also done very well against some newer - 06` Z`s in short, unscientific straightline tests (up to hwy speeds - define that as you will )
The car is a pleasure to drive, tire-eating notwithstanding!
Jack
Old Apr 22, 2007 | 09:30 AM
Zridder19's Avatar
Zridder19
Im close to the setup you are running now and pretty happy with the power...but its time to move on for me. I need more! twins are coming soon.
Old Apr 22, 2007 | 01:09 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Is that the 3" single exhaust?
Old Apr 22, 2007 | 03:12 PM
teacher's Avatar
teacher
Default JIC single is 80 mm - 3.1``
Yes, 3`` and a work of art. Huge, great quality. A bit boomy from 2100-2700, but o rasp with the resonator. Great sound under full throttle too. B-pipe/after y-pipe back - about 6` to the tip.
Old Apr 22, 2007 | 06:08 PM
OCZTrack's Avatar
OCZTrack
Taking out your spare tire is a mod?
Old Apr 22, 2007 | 06:12 PM
Chako135's Avatar
Chako135
...it saves weight = weight reduction = "mod"
Old Apr 23, 2007 | 07:45 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Sounds to me like you actually let your car finally breath since putting in intake and plenum mods.
This stuff does work really well as a team...
Rick
Old Apr 23, 2007 | 07:52 AM
ZLadie2000's Avatar
ZLadie2000
u should tune it with utec for even more power and dyno
zracin's Avatar
zracin
+2 timing with consult? please explain. does this mean you advanced your timing i assume?
Old Apr 23, 2007 | 10:37 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Yes he means +2 degrees of timing. I noticed on the dyno that doing this makes power ... I did it using Cipher tool from AAM.
Old Apr 23, 2007 | 11:49 AM
Abishop's Avatar
Abishop
id say, if your happy with n/a mods, your a lucky man.
Old Apr 23, 2007 | 11:53 AM
Fluid1's Avatar
Fluid1
I have the JIC single, 80mm no res. I love it, absolutely love it.
80mm= 3.15"
Get it dyno'd!!
Old Apr 23, 2007 | 11:54 AM
ct350z's Avatar
ct350z
im pretty dam happy with all my n/a mods, but the best mod had to be my utec!!! hands down!!!
Old Apr 23, 2007 | 12:05 PM
Drock's Avatar
Drock
Hi,
is it recomended to remove the spare tire? I thought of this too for weight reduction...
but I have not removed it yet.... as I figured it was factored in for crash tests etc... and would be dangerous not to have it incase of a heavy rear impact?
cause even if I got a flat tire.. I would not use it anyways.... with my lip kit + 19's + lowering, would probably be on the floor LOL.
some advise on this would be great... if so, ill remove it...!
Old Apr 23, 2007 | 12:09 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Drock
Hi,
It only weighs 40 lbs.
If you want to drop serious weight, the best place to start is the wheels.
You say you have 19's. You will not notice any difference if you take the spare out.
Old Apr 23, 2007 | 12:35 PM
Drock's Avatar
Drock
hi,
really its only 40 pounds.. but I guess thats something... I feel a huge difference from when Im alone in the car, compared to when I have a passenger..
yes for sure the 19's add weight...
but would it be dangerous to remove it?
Old Apr 24, 2007 | 02:17 PM
teacher's Avatar
teacher
Default safety of spare removal
I`m not an engineer but...
a 40lb hunk of steel and rubber will likely provide a minute amount of extra protection under the best of circumstances. The odds are that you`ll take one on the sides or nose in an accident anways, so the rear impact area will not be a factor. If the car is flipped and the roof comes into play don`t be in your friend`s 350z vert.
Jack
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
