Amuse R1 Titanium with a TWIN turbo?
Old Apr 23, 2007 | 12:38 PM
GQ 350z's Avatar
GQ 350z
Default Amuse R1 Titanium with a TWIN turbo?
How will this exhaust compare to a comparable true dual? What is recommended for this to flow around 500-550rwhp range? Only reason I am sticking to this exhaust is because of sound
If performance is seriously compromised I'll use something else.
ravi
Old Apr 23, 2007 | 01:00 PM
kwiker's Avatar
kwiker
Shift_Dorifto
I'm confused...what do you mean, reverse y-pipe?
Old Apr 23, 2007 | 01:10 PM
GQ 350z's Avatar
GQ 350z
Ok I think I must have been smoking crack!
I have read too many turbonetics threads where people hack the exhaust.
So NEW QUESTION:
ravi
Old Apr 23, 2007 | 02:10 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you ask me, it's purely a N/A exhaust.
Old Apr 23, 2007 | 02:36 PM
kwiker's Avatar
kwiker
Shift_Dorifto
Yeah...i agree. It is a single 3 inch pretty much, it just splits back off into 2 tips at the end...kinda like stock.
I would definately do a true dual setup...well if i had spent the money on a turbo setup...i would just run a custom single on each side. (duals) Actually, i'm pretty crazy, i'd probably just dump them right behind the front wheels...i'm crazy like that. When my Buick was running, I would run open downpipe all the time. But your in cali so you can't do that, just get duals. I'm out.
Old Apr 23, 2007 | 04:13 PM
jonnylaw's Avatar
jonnylaw
The Amuse is for NA--A true dual would be much more fitting for a turbo setup imo
Old May 13, 2007 | 01:04 PM
Zivman's Avatar
Zivman
So NEW QUESTION:
ravi
your exhaust note will completely change with the addition of turbos. the turbos will tame your exhaust note quite a bit. I really like my 2.5" aps, though I wouldn't mind it being a tad louder under WOT. The APS 3" is crazy loud. Other than that, I am sure the evoTT sounds great, and the exhaust SVRTech puts out has a nice tone. AAM makes some FI exhaust as well. You have choices, but I doubt you fill find one that sounds as exotic as your amuse
Old May 14, 2007 | 09:14 AM
Nismo 350z's Avatar
Nismo 350z
Exactly. Those are great FI exhaust systems. The Amuse R1 is purely NA. Although if you were running a TN single, then the R1 should work fine with it. OP-since u are looking for max performance, any of the TD exhausts Zivman mentioned will work great with a TT setup.
Old May 14, 2007 | 10:50 PM
turismo's Avatar
turismo
I have something similar to it. I regret not going with a true dual
Old May 15, 2007 | 06:09 AM
THE TECH's Avatar
THE TECH
Just depends on your overall goal. The Amuse might be restrictive, but you can't argue with the added weight that you'll have to deal with with a true dual.
Old May 15, 2007 | 06:26 AM
AboostedG's Avatar
AboostedG
Twin Spoolin
TRUST ME!, if it were at all possible, I wouldn't be in the process of selling mine right now. If everyone were to go SC or ST w/ this exhaust, then it wouldn't be a problem whatsoever. I'm going to regret letting it go, but i'm gaining so much more if I do so. Plus, if they ever make a Dual Amuse, you better believe i'll have the Amuse back in my lineup.
There's no way i'm dishing out the price of a TT Kit for that ARC one, just plain ridiculous! I'd rather have the weight of a different exhaust instead cause that ARC Isn't going to give you 20+ hp, when I can put 5K towards other things I need/want.
Old May 15, 2007 | 06:32 AM
THE TECH's Avatar
THE TECH
I just recently changed from the Greddy EVO TT (true dual) to the Amuse. I'm not upset one bit.
Old May 15, 2007 | 06:55 AM
AboostedG's Avatar
AboostedG
Twin Spoolin
Yeah, but you have a SC, not a High Boost TT... correct?
Old May 15, 2007 | 07:21 AM
THE TECH's Avatar
THE TECH
That is correct.
Old May 15, 2007 | 07:41 AM
AboostedG's Avatar
AboostedG
Twin Spoolin
Well I don't blame you for the change then, I would have done the same thing if I were in your situation.
Old Jun 20, 2007 | 03:36 AM
CESAROTORRES's Avatar
CESAROTORRES
Default Amuse true dual
Amuse has now a true dual.
http://www.bulletproofautomotive.com...il.php?ID=6284
I ordered the ARC TI, but never made it to the US. (disappointed at ARC)
Cesar
PS.
I might order the amuse dual for my Power Enterprise TT.
mhoward1
Nov 26, 2008 09:04 PM
jonnylaw
Nov 30, 2007 05:21 AM
