Quick exhaust gasket question...
Old Apr 26, 2007 | 02:12 PM
drewb612's Avatar
drewb612
Default Quick exhaust gasket question...
I am installing my exhaust now and i bought the exhaust used. The guy included the old gaskets but they are no good, the diameter of these gaskets are 2.5"...however when i measure the pipes themselves, they are only 2.25"...do i need to buy the 2.5" gaskets or will I be ok with a 2.25" gasket which is the actual diameter of the pipes themselves
Old Apr 26, 2007 | 02:18 PM
hardrock905's Avatar
hardrock905
It depends on how you are measuring the gasket for one thing. Inside diameter, outside diameter, on-center?
I am no mechanic, but what I would do is hold the gasket up to the flange and see if it lines up correctly.
Also, if the gasket is from the exhaust you bought, chances are it's the right size.
Old Apr 26, 2007 | 02:19 PM
drewb612's Avatar
drewb612
well the id of the new exhaust i bought is 2.25"...so technically a 2.25" gasket would fit the opening perfectly...
Old Apr 26, 2007 | 02:20 PM
davidf's Avatar
davidf
It will work fine but you'll be slightly restricted. The best fix is go to any good parts store and ask for Permatex Ultra Copper red silicone, part no. 101BR. You can thow away your gaskets with this stuff. You still can most likely get the 2.5 exhaust gaskets there also. That a pretty common diameter.
Old Apr 26, 2007 | 02:27 PM
Eazzy's Avatar
Eazzy
Stock reusable Gaskets have oval openings that are 44 mm X 31 mm. That is 1.70 X 1.23 in. or so. I dont know where you are getting 2.5 -2.25.
Lay the steel OEM on the header and make a judgment. Use Anti-Seize on your bolts/Nuts needless to say, but also brush down the steel OEM Gask. with it also
Also --torque in increments from center out
Old Apr 26, 2007 | 02:33 PM
Eazzy's Avatar
Eazzy
My bad--just relized you were talking collector side---No reason, if the material is there that a gasket cant be trimmed for ID
AND ---no reason on NA that you cant buy a sheet of exhaust gasket material and make your own
Old Apr 26, 2007 | 02:54 PM
davidf's Avatar
davidf
Back when I was searching franticly late one evening for 3" gaskets {with no luck} seems everyone had 2.5"s.
Old Apr 26, 2007 | 02:56 PM
Fluid1's Avatar
Fluid1
Can you elaborate on the 101BR?
Old Apr 26, 2007 | 05:17 PM
davidf's Avatar
davidf
Sorry that is the Permatex gasket maker part number on the tube. This stuff is fantastic high heat silicone that will not break down. You can use it in place of exhaust gaskets.
Old Apr 27, 2007 | 06:38 AM
Fluid1's Avatar
Fluid1
Thanks!!!!
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
Mattg350z
Oct 2, 2015 06:51 AM
