new turbo xs test pipes
Old May 1, 2007 | 08:26 PM
phatjohnathon's Avatar
phatjohnathon
Default new turbo xs test pipes
I just got a set of the turbo xs test pipes installed on my 06.. sounds great but Im hearing alot of negative feedback on the pipes saying that my engine will mess up and have problems with my seals, does anyone know if the test pipes are known for this
Old May 2, 2007 | 05:03 AM
ML2000's Avatar
ML2000
I have had them on my car for 5000 miles now and have not had any problem with them. I think the negative feedback your getting is wrong and I would contact a company that sells them if you any have concerns. One company that sell them on this board is Forged Performance (www.forgedperformance.com). Hope this helps.
Matt
Old May 2, 2007 | 06:41 AM
Nihilation's Avatar
Nihilation
Anyone who told you that is an idiot. .
Old May 2, 2007 | 06:45 AM
Question
How do test pipes mess up a motor, and cause the seals to leak?
Old May 7, 2007 | 11:16 AM
jumpin800agl's Avatar
jumpin800agl
8 to 11
I just recieved mine in the mail and there was not any new mounting hardware. Are the stock bolts reused?
Old May 8, 2007 | 07:29 AM
phatjohnathon
stock nuts and bolts are used
Old May 8, 2007 | 02:40 PM
first350's Avatar
first350
The main problem w/ cheaper TP's is not that these mess the engine up, it's that the welds are known to break...since changing TP's is more time involved, and a good set (i.e. AAM, Strup, Nismo...) is usually not much more $$, ppl always rec'd that you just buy a good one to begin with.
Only other issue would be fitment, but since it sounds like you got them installed, the fitment should be decent.
*TP's do require non-foulers or some other method to trick the ECU - but that's irregardless of the company that makes them.
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
