Greddy EVO 2 rattles?!
Old May 25, 2007 | 08:15 PM
Doc25398's Avatar
Doc25398
Default Greddy EVO 2 rattles?!
I have a Greddy evo 2 exhaust that I bought used off of another member. I am just frustrated with the exhaust because everytime I go over a small dip in the road, I hear it rattle pretty moderatly. I went underneath the car a few times, but theres no way I could tell where it is coming from. From inside the car it sounds like it is where the tips are. Does anyone else have these issues. I searched a few times, but I couldnt really find anything pertaining to this topic. Thanks.
Alex
Old May 25, 2007 | 08:22 PM
THE TECH's Avatar
THE TECH
Only spot that I would think it could hit something is the large V-brace underneath the car.
Old May 25, 2007 | 08:39 PM
Doc25398's Avatar
Doc25398
I will check underneath there, and see. Is it possible that *** I go over a dip its rattling within the hanger?
Old May 25, 2007 | 08:44 PM
THE TECH's Avatar
THE TECH
Since the exhaust is hung on a rubber mount, it is highly doubtful that the hanger is causing the issue. You probably just need to get under the car and check the entire exhaust. I'll bet that you'll be able to spot it.
Old May 26, 2007 | 08:11 AM
rynzy's Avatar
rynzy
my greddy evo rattles like no other. checked it out and i am hitting the rear sway bar and middle brace. i spaced the brace down about 1/2 an inch or so. the swar bar has me baffled. i've change hangers and the problem goes away for a day or two tops and then returns. then goes away and then returns again. i've uninstalled the system and reinstalled to make sure everything is good to go and the same end result. not sure what to do on this one. any help would be cool on that one. i spoke with greddy and they assured me they have no clearance issues with the system. but i got your back on this one...
you pay almost triple digits for an exhaust system that sounds like it's falling apart...don't like that too much. thinking about just putting my home made test pipe back on and reinstalling the rest of the factory system...
some one help us
Old May 26, 2007 | 02:16 PM
THE TECH's Avatar
THE TECH
Your only other option is to get the Nismo exhaust hangers. They are stiffer than the stock ones so it could help with your exhaust flexing the stock hangers and hitting the sway bar.
Old May 26, 2007 | 05:14 PM
Doc25398's Avatar
Doc25398
are they that considerably stiffer than the stock?
Old May 27, 2007 | 02:24 AM
stylett9's Avatar
stylett9
do you have aftermarket rear sway bar? Mine clears the stock one fine but i did have the problem of it vibrating on that big black brace underneathe. Solved it by putting some washers in the bolts to space it a little.
Old May 31, 2007 | 04:55 AM
Datona Jess's Avatar
Datona Jess
I have one as well and I have to say mine is fine once I did what Stylett did
Also have you double checked that when you relocated your evap canister that is not what is causing the rattle?
Mine was a rattly trap like yours seems now because the evap canister was hitting the "plate" I had built.
I took it off with a buddy and put some foam on it and now my car is rattle free..
just another thought.
Good luck!
Old May 31, 2007 | 07:48 AM
rynzy's Avatar
rynzy
i have an 07...there weren't any suspension changes made to the car right???
Old May 31, 2007 | 08:51 AM
MASTERPLAU's Avatar
MASTERPLAU
I had that problem at the very beginning. I blamed it on a poor install... It hasnt rattled since i had adjusted it...
Old May 31, 2007 | 10:07 AM
Doc25398's Avatar
Doc25398
Thank alot stylett and daytona, I completly forgot about the black relocation brace. I added some washers and it has reduced the rattling. I will take it out again and add some foam to see if it completly eliminates it. I completly forgot about the canister. Thanks.
Alex
Old May 31, 2007 | 10:24 AM
rynzy's Avatar
rynzy
so the canister huh??? trying it tonite. also gonna reinstall the system and check for errors in my install...
any other ideas before this evening???
Old May 31, 2007 | 11:47 AM
Datona Jess
I would say make sure when you put the hangers into the rubber grommet that you use some lube to make sure they go in fully.
I had just about every issue you could have installing mine...
Good luck though!
Old May 31, 2007 | 12:22 PM
97supratt's Avatar
97supratt
All you guys need to do is loosen the bolts (dont remove them). Put spacer in between the exhaust and the braces or anything that it might get into contact with. Tighten the exhaust bolts then remove the spacers you originally placed. You should have some space in between the exhaust system and the objects.
Old Jun 19, 2007 | 04:13 PM
Doc25398's Avatar
Doc25398
Well I finally got my pro 1 test pipes installed in the car, and now theres a wierd rasp/rattle but only when the rpms come down around 2500-3000rpm. I took it to an exhaust shop and herad themn rev it on the lift, the noise is coming from the X pipe resonator piece. The guy was going to cut it out, and put a straight pipe. I was not sure if this was a good idea so I told him I would come back. He said that the glass pack may be going out?! if that is possible I dont know. Also I found that the exhaust rattles when i hit it right before the big mufflers, but it is not hitting anything at all, and the last part that attaches the canister to the main exhaust had no gaskets, but the shop said that it wasnt needed since it was a machined surface. This exhaust is beging to turn into a nightmare. I do know that it never made that noise before the resonated test pipes. Do you think I should just go ahead and get the straight pipe put in, and worry about the rattling in theback portion of the exhaust later????Sorry for the rant guys its just driving me mad.
Alex
Old Jun 19, 2007 | 05:36 PM
Abishop's Avatar
Abishop
sounds like the inside of the resonator mesh weld has broke off and rattling.
Old Jun 19, 2007 | 06:45 PM
angelzhope720's Avatar
angelzhope720
I haven't had the most pleasant exhaust experience either. Just keep trying and you'll get it right, don't give up! I know I almost did.
Old Jun 19, 2007 | 08:05 PM
Doc25398's Avatar
Doc25398
Thanks alot guys. do you think I should just take the chances of cutting out the resonator in the Y pipe and replace it with straight pipe?
Old Jun 19, 2007 | 08:24 PM
Abishop's Avatar
Abishop
cutting the x pipe out to make straight pipe is not a bad idea, you might have more rasp because of minus one resonator but other then that it wouldn't hurt, true dual then.
