HKS exhaust question?
Old Jun 24, 2007 | 12:47 PM
TimeAttkZ's Avatar
TimeAttkZ
^ thanks.
As far as test pipes go ... well get resonated to minimize the rasp. You will still get a little no matter what, so keep that in mind.
Headers are typically not worth the pain in the a$$ to get them installed. They can be extremley hard to fit in the small space we are given. If your going to do headers, the only one worth the time is Crawford from what I understand. They also are the hardest to install. So weigh your options... I found that I just couldnt bring myself to spend 900 on the headers plus like 500 or more on install. It all depends on your plans... Often times poeple lost power on the dyno with some of the headers offered for our cars. So make sure you do your research before you dish out the $$.
Old Jun 24, 2007 | 04:47 PM
jason350z's Avatar
jason350z
Originally Posted by TimeAttkZ
^ thanks.
you have test pipes, what do you do every time you need to get the car inspected????
Old Jun 24, 2007 | 05:04 PM
md350's Avatar
md350
You'd have to change them out. But how often is it getting inspected?
Using test pipes is illegal for street use. They will not pass a simple visual inspection.
Old Jun 24, 2007 | 11:04 PM
TimeAttkZ's Avatar
TimeAttkZ
exactly
Old Jun 24, 2007 | 11:22 PM
gsazabi's Avatar
gsazabi
Originally Posted by jason350z
thanks every one this helped alot.
is it hard to install headers and test pipes?
considering i installed the hks alone without a lift just stands.
which headers and testpipies do you recomend? what you guys do everytime the car needs to be inspected cause they are illegal
Installing test pipes is fairly easy.
Installing headers is a biaotch..just pay someone to do it unless you truly love doing stuff like this.
As far as headers, I would recommend Crawfords.
Test pipes, there are a lot of choices out there. UTR resonated TP is one of better choices.
I've also had experience with Fast intention and Titek TP, and I can tell you that their quality is very high.
Old Jun 25, 2007 | 09:30 AM
jason350z's Avatar
jason350z
thanks ya'll
thats a pain having to remove them i think. maybe i should go with another mod- like turbo xs utec any coments on this!!!
in the future i see my self going FI
Old Jun 25, 2007 | 09:55 AM
Lawy'dU's Avatar
Lawy'dU
I have had the HKS exhaust for a month now. It is not loud as I thought it was going to be and also like I’ve heard in videos. I’m starting to think there is a leak where the pipes connect, either the cat to the Y pipe or the Y to the muffler. Could that be the cause?
The exhaust gets loud after like3.5- 4rpms , other wise not really loud. At 3.5 4 the sounds is more high pitch which is what I like other wise the sound is more like a low tone
How can I check if there is a leak? Or is this the way the exhaust sounds and I’m just being paranoid. I don’t get any lights or anything the car runs fine.
the HKS system doesn't have a Y pipe lol. It's a full dual exhaust.
Old Jun 25, 2007 | 10:00 AM
jason350z's Avatar
jason350z
thanks ya'll
Old Jun 25, 2007 | 10:03 AM
gsazabi's Avatar
gsazabi
thanks ya'll
Not worth it with the mods you have. Get more mods before it and you'll gain greater results.
BTW, you can REALLY use some search feature. Many of these topics have been covered before.
Old Jun 25, 2007 | 10:14 AM
RandomHer0's Avatar
RandomHer0
I have Fast Intentions TP with the HKS Exhaust and it SCREAMS. Not 72 hours later when I had it installed I was ticketed I won't replace it though...
Old Jun 25, 2007 | 11:18 AM
gothchick's Avatar
gothchick
Ahhhh, ya beat me to it~ Lol! :-)
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
