something is wrong..
Old Jun 26, 2007 | 03:16 PM
steppinrazor's Avatar
steppinrazor
Default something is wrong..
... my car has been acting funny since i installed the kinetix v+(about 3 days ago), i have lost power, and i get this deep gargling sound when i press the gas while in gear, if i keep the car in nutral and step on the gas it sounds just fine... anyways i took it in to get looked at today, they told me my car was fine and charged me 100 for it, any ideas please im fu*kin desprite
Old Jun 26, 2007 | 03:18 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
could be a leak in the plenum or the throttle body could be out of sync.
Old Jun 26, 2007 | 05:25 PM
steppinrazor
thats what i told the mechanic, he told me again everything was fine with it... how can i find out?? or what would you all do?
i also forgot to mention that it takes about 20 min. of driving before anything starts to act up, for the first 20 it seems pretty fine
Old Jun 27, 2007 | 03:36 AM
SpeedRcr's Avatar
SpeedRcr
if there is a leak in the spacer...just spray some water around the sealing to find bubbles...else it could be your bolts are not tightened down
Old Jun 27, 2007 | 03:51 AM
03aeroZ's Avatar
03aeroZ
its not hitting the hood is it? sounds like after 20min when it warms up and under load it may be hitting the hood. long shot, but that is what happened when i put on my spacer.
Old Jun 27, 2007 | 04:37 PM
steppinrazor
if thats the problem how would i fix that?
Old Jun 27, 2007 | 05:23 PM
THE TECH's Avatar
THE TECH
Are you using the stock hood? If so, the plenum shouldn't be hitting it. If it was hitting the hood, you could tell from looking at the upper plenum as well as the underside of the hood.
If that isn't it, you might want to go back to stock and see if that cures the issue.
gorilko
Aug 22, 2013 08:25 PM
SoCal-Greenz
Apr 23, 2013 06:17 AM
phiooz
Texas Marketplace
Oct 4, 2012 04:57 AM
LODOSS
Oct 23, 2006 01:55 PM
paranormal
Oct 23, 2005 09:25 AM
