Welding Titanium question HELP FAST!
Old Jul 13, 2007 | 09:37 AM
DmanG281's Avatar
DmanG281
I'd go spend the money on a tungsten bit and try to drill it out. Worst case scenerio I'd cut the flange off as close as possible and make it a slip fitting and just put a collar around it. You may also want to look at the welding/fabrication section on Honda-Tech.com They have some really skilled guys over there and I'm pretty sure a couple of reps for Miller frequent the forums as well.
Old Jul 13, 2007 | 09:45 AM
scratch137's Avatar
scratch137
Im going to the exhaust shop now, i will bring all your guys' ideas with me. THanks you much.
Old Jul 13, 2007 | 11:17 AM
HondaKiller's Avatar
HondaKiller
It sounds like he wasn't qualified to mess with it from the go, lost the gaskets removing the cat? how the f*ck do you just lose a gasket? It doesn't blend into the ground very well last time i checked Good luck with things.
Old Jul 13, 2007 | 02:07 PM
scratch137's Avatar
scratch137
Hey ok all is well. He was able to get the bolts off. 1 thing tho, he used some black gasket sealer instead of normal gaskets. Is this ok?
Old Jul 14, 2007 | 06:53 AM
sry110's Avatar
sry110
Like some sort of silicone sealant? I suppose it would do the trick, as long as it doesn't burn away. Might want to replace it with actual gaskets at some point down the road.
Old Jul 14, 2007 | 07:22 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Silicone sealant? Did Mickey and Minnie say hi to the kids when you were there???
What kind of exhaust shop DOESN'T have gaskets??? You need to shop around better....
Rick
Old Jul 14, 2007 | 11:31 AM
scratch137's Avatar
scratch137
They had gaskets, just none that would fit. They used some black stuff that looked like tar lol. They said as it heated up it would seal and be good as a gasket.
Old Jul 14, 2007 | 01:05 PM
ISMSOLUTIONS
Rule 1 - the only glue you use for exhausts - is WELD...
Old Jul 14, 2007 | 02:08 PM
350Z84's Avatar
350Z84
If it was like RTV sealant I would think this would burn off. You should get a real gasket on there.
Old Jul 14, 2007 | 07:00 PM
CLETUS's Avatar
CLETUS
RTV (silicone) should work but it is messy and might look pretty crappy. a half way decent exhaust shop should have had some gasket paper and MADE the gasket. 1 question though, after the guy at the shop said he could do it, and you were advised not to weld the ti, why did you take your car to a shop that obviously did not know what they were talking about??????
Old Jul 14, 2007 | 08:30 PM
scratch137's Avatar
scratch137
he never said he could weld it. he wasnt sure if he could. and i took it there because its the only one i know of. They other car speed shop around here wouldnt have been able to see my car when i needed them to, and they would charge and arm and a leg for the same thing
Old Jul 15, 2007 | 09:29 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
If you have a Ti y pipe, I would just take the time needed to drill and ream out the threads with a air die grinder and tungsten carbide cutting tip.
It won't take too long to do but take your time.
And skip anything that has to do with welding Ti unless your guys know how to work with Ti. Its very hard to weld. Its not like steel at all.
Old Jul 15, 2007 | 09:36 AM
ISMSOLUTIONS
Default ...not going to find a Ti welder anywhere close or easy!
Here's a little info all...the simple realization is this - you buy a Ti exhaust, you better hope it never needs repair. The only really way to do anything with it, conventionally, is to cut and clamp it.
http://www.azom.com/Details.asp?ArticleID=1245
Old Aug 15, 2007 | 10:42 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
So how much would it cost to GTA weld a crack in a titanium exhaust? Also, where would I find such a person/shop?
Old Aug 16, 2007 | 04:12 AM
Hydrazine's Avatar
Hydrazine
Contact someone in the rocket propulsion or aerospace industry.
Old Aug 16, 2007 | 06:11 AM
ISMSOLUTIONS
+100000000
and good luck!!!
Repairs here involve cutting the bad piece out and them clamping it to replacmeent pipe.
Old Aug 16, 2007 | 06:21 AM
Ruthless18x's Avatar
Ruthless18x
I thought titanium could be field welded? I know that there are certified welders capable of welding titanium, stainless, etc. outside of such industries. They might not be right for such an application, but they do exist.
Old Aug 16, 2007 | 06:28 AM
  #38
ISMSOLUTIONS
When I researched this before...I remember there only being about 3 locations int eh US that can do this commercially...I don't remember anymore where and who though...none were SoCal Local..I know that.
Rick
Old Aug 16, 2007 | 06:36 AM
  #39
Ruthless18x
Rick
Yeah commercially you are right. Industrial/Construction wise there are quite a few.
Old Aug 16, 2007 | 07:13 AM
  #40
ISMSOLUTIONS
Yep - 11 - I'll see if I can find the info again.
Rick
