Welding Titanium question HELP FAST!
Old Aug 16, 2007 | 08:39 AM
  #41
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Originally Posted by Hydrazine
Contact someone in the rocket propulsion or aerospace industry.
I highly doubt there's neither of the above around where I live, but I'll try. Thanks for the tip.
Old Aug 16, 2007 | 08:44 AM
  #42
scratch137's Avatar
scratch137
Lol, hmmm aerospace industry ehhh... well i live in florida lol looks like if my **** breaks ill just have to drive to NASA and ask them to reweld it for me. I think you could consider them the rocket propulsion / aerospace industry leaders dont you lol.
Old Aug 16, 2007 | 08:47 AM
  #43
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
I'd love to see how that works out for ya!!! Don't think of holding your breath ;-)
Lets see - a 4" weld could cost a measly $1000 or so...
Old Aug 16, 2007 | 08:58 AM
  #44
3hree5ive0ero
Retired Admin
Actually, I found a couple of places around where I live who can and will do Ti welds. Hopefully, they turn out for the better.
Apparently, a lot of motorcycle shops are able to do TIG welding and they're not too hard to find. Also, if you have race shops (which is where I'm taking mine, I think), they'll most likely be able to do it. Craigslist also returned one person who is ASME certified and can do Ti welding.
Anyway, I'll most likely get this done today or tomorrow, so wish me luck.
Old Aug 16, 2007 | 09:29 AM
  #45
go-fast's Avatar
go-fast
welding titanium is not that hard,just make sure they gas shield the inside of the pipe and stress relive the welded area after it cools.
Old Aug 16, 2007 | 09:30 AM
  #46
ISMSOLUTIONS
VERY COOL!!! Let us all know who, what and where...very good info to have!!! Some pics of before and after, and even their shop would be beneficial as well....if you can.
Rick
Old Sep 23, 2007 | 11:18 AM
  #47
lovetoclown's Avatar
lovetoclown
Any updated info on this?
Old Sep 23, 2007 | 12:12 PM
  #48
3hree5ive0ero
Retired Admin
If you're referring to me, then yes, I did get this done. It was welded at Brink Racecraft in Irving, TX. They do a lot of the welding work for other performance shops also. It didn't cost much to do it (I paid $60 to get the cracks welded), neither. Overall, they did a very good job of welding. I think the easiest way would be to find a reputable performance shop near your area and ask them where they get their welds done. Then ask that welding shop if they're qualified to TIG weld and if they are, get it done there.
Old Sep 23, 2007 | 01:25 PM
  #49
lovetoclown
and you had Titanium welding done?
Old Sep 23, 2007 | 01:31 PM
  #50
3hree5ive0ero
Retired Admin
I'm guessing you didn't read the whole thread?
Yeah. I used to have a Fujitsubo Super Titanium exhaust, which is a fully titanium exhaust. Part of the exhaust had a crack (long story), which was professionally GTA welded by a race shop.
Old Sep 24, 2007 | 05:08 AM
  #51
lovetoclown
I did read the entire thread. Just wanted to clarify. thanks.
Old Sep 24, 2007 | 10:40 AM
  #52
go-fast's Avatar
go-fast
did they stress relieve it ? if not it will crack around the weld.
Old Sep 24, 2007 | 01:08 PM
  #53
3hree5ive0ero
Retired Admin
What (and how) is stress relieving? Also, the crack was caused by an abnormal upward pressure on the exhaust system (from a dyno day). They strapped down the car wrong, where the strap was pushing up against the midpipe. The unnecessary stress already on the midpipe, in addition to the car squatting down with force during the dyno runs, caused the crack in the midpipe and also caused the ypipe to break both of its flex joints. Under normal conditions where there's very minimal movement in the exhaust system, there shouldn't be any cracks around the newly welded.
Old Sep 24, 2007 | 01:44 PM
  #54
go-fast's Avatar
go-fast
mixed alpha-beta alloys(titanium)are sensitive to micro changes caused by heating and cooling above 1500f ,and are subject to embrittlement by welding.welds on commercially-pure titanium may be stress relieved at 1000f and air cooled.basically the welding made that section of the pipe very brittle and to help the areas around the weld not crack you need to heat to 1000f.
Old Sep 25, 2007 | 12:16 AM
  #55
Quamen's Avatar
Quamen
And this is especially important since it sounds like someone just TIG welded it in open air. Even if you use lots of shielding gas it is still not the proper way to do it and there will be embrittlement from impurities.
Old Sep 25, 2007 | 05:03 AM
  #56
go-fast's Avatar
go-fast
+1 if the pipe is already mounted just make a couple of passes with an oxy-acytl torch with the oxygen turned up past the point that the flame is acceptable for cutting.you dont want glowing metal but close,it's not ideal but better than waiting for it to shatter like cast iron.EDIT they also sell temp strips that tell you what temp you have reached,it should help if your torchman has little experience with ti.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
