Need some help concerning Motordyne spacer
The MREV2 fits exactly like stock because its a modified stock lower plenum.
So using a spacer with it will be exactly like what you have now.
Both fit no problem.
ok good thanks, last question in the past i have loosen the the nut in the strut bar i dont know have it came from stock. how tight do i need to make it. can i do it with torque wrench and if so how many pounds? i just dont know if its supposed to be very tight, midium or etc..
thankx
thankx
1.7 turns on the tensioner bolt.
+/- a small amount for fine tuning the bar heigth between the plenum and hood.
Its described in detail in the installation manual.
Originally Posted by Mast3rShak3
i have manual but i kinda dont want to buy the rev add on for 500. Just the iso thermal spacer 4/16
Its a completely different design.
BUT on the other hand, when you install the MREV2 and spacer on a REVUP, it will make more gains than any other bolt on short of nitrous or FI.
well the thing is that in order to line up the strut bar with the wholes, i had loosen it alot till the screws slide easily but i didn't keet track of how many turns i did to loosen the strut bar. so if i do 1.7 turns its not going to be tight at all. so how do i know if its tight enough
Its 1.7 turns after the bar is set in, with the brackets bolted down and with the bar in a relaxed position. (Regardless of where it was at previously.)
hi guys....
i have a 2004 350z auto transmission, with custom headers and direct exhaust system, greddy intake and a unichip, and im not sure what motordyne product should i get because all this rev up and non rev up is making me confuse...
Originally Posted by slow wind
hi guys....
hi guys....
Hydrazine, I'm interested in the 1/2 inch Plenum Spacer with the MREV2. I know the 1/2 inch spacer will NOT have allowance for the stock strut bar as well as enclosure of the hood. But what if I used either APS strut bar or the Stillen strut bar? Will it fit then? I figured it would since those strut bars are configured to be fitted lower towards the end of the hood and away from the top of the plenum itself.
not trying to highjack at all but is the stock strut bar good? will the aps help in handling or rigitity at all or the same basically just for looks and clearence. Sorry just didnt see the point in making a new thread for this.
I know it fits, but otherwise I've never used a APS strut bar so I can't comment on its quality or function.
Many others on this board could answer this for you.
Originally Posted by ohSIXz
you have the NON-revup. which means dont get the MREV2. order the 5/16 iso-thermal plenum. problem solved and international relations all better again
I have an 06 5AT Z and I want an aftermarket plenum. Is this what I should be looking at? Even though it says 03-05.
http://www.thezstore.com/page/TZS/PROD/LNP02/11-3097
Edit: I think I've got it. ATs have different lower plenums than Rev-ups, giving them more torque. So all we ATs need is a spacer kit, as opposed to a plenum assembly because ours is already good enough. Correct?
That's it. Just get a spacer and you're done with the intake section.
After that you could get an exhaust. Then cats or preferably test pipes.
If you do all that you will have some good gains.
The next thing to do would be a ECU reflash or some kind of engine management.
