Agency Power Ti Exhaust silencer
Old Jul 23, 2007 | 09:27 AM
ill350's Avatar
ill350
Default Agency Power Ti Exhaust silencer
I just installed an Agency Power Ti Exhaust, and although I LOVE it, the thing is LOUD! Ive already had 3 complaints as I am waking up everyone in the neighborhood when I leave for work at 5:30am. Anyway, I am not getting rid of the exhaust, so just wanted to know if any of you know where I can get a silencer for it.
-I've already contacted Agency Power, they dont make one
Old Jul 26, 2007 | 08:52 AM
Chineseguy's Avatar
Chineseguy
Im sure a JIC silencer works for it.
Old Jul 26, 2007 | 12:50 PM
97supratt's Avatar
97supratt
Nope there is no silencer for that exhaust and nothing will fit. I am probably the only damn person on this planet that tried it and it was a pain in the a$$.
First, the size of the tip isn't a 4.5", it is a abnormal size which you cannot find a silencer for.
Second, it doesn't have a hole for you to put a bolt through to hold the silencer therefore you have to drill through it. Since the tip is titanium, good luck drilling through titanium with a steel drill bit. lol My drill bit turned orange then yellow before it finally make a tiny hole in the tip. lol
Third, it won't work. I had to cut up the silencer into bits and pieces to make it fit and when it finally did, I mean it did quiet the damn exhaust but it made such a nasty rasp that I threw it half way across the street because half a days worth of work went down the drain.
That was a sweet write up.
Old Jul 26, 2007 | 01:18 PM
ill350's Avatar
ill350
Thanks for the heads up, I guess I will just sucomb to the fact that I have a loud *** exhaust.
Old Jul 26, 2007 | 01:35 PM
97supratt's Avatar
97supratt
Here's some advice. Put your stock cats back on, or add resonators on your y-pipe.
Old Apr 19, 2011 | 09:48 AM
xNeo's Avatar
xNeo
http://www.amazon.com/UNIVERSAL-inch.../dp/B0035V2UAY
Do you guys this is worth trying?
Old Apr 20, 2011 | 07:19 PM
Mikey3288's Avatar
Mikey3288
Haha I was in the same boat as you, go to ebay and search "4.5" silencer" and you'll see a few. I bought one that was "adjustable" it had like these little vents that you can open up for more flow. They're only 16 or so shipped.
What I did was shove the silencer pretty far down to the point where you can't really see it. It's kind of hard but you have to drill to match the hole on the silencer. I used a dremel for what seemed like a life time but I eventually punched through. I drilled on the bottom of the tip so it's pretty stealthy. First time I started the car it was so quiet I didn't even think it was on!
Old Apr 22, 2011 | 10:53 AM
kramykram's Avatar
kramykram
i ordered about 10 of them off ebay before i found one that fit, then like an idiot sold it. now i can't find another. the jic silencer will fit perfect just need the 114mm one. i drilled a hole in mine with a cheap cordless drill from harbor freight it did the job just fine. now since i went back to high flow cats i want another. its killing me on long drives.
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
