Borla TD and cutom x-pipe?
Old Nov 10, 2007 | 05:27 AM
HondaKiller's Avatar
HondaKiller
Good deal. Sounds damn close to mine. Even cleaner sounding i think, and i have HFCs. I would like to hear it with the RPMs up a little a bit. Nice job setting something up for test pipe guys who can't stand rasp.
http://www.youtube.com/watch?v=XGW6PzycmvA
Old Nov 10, 2007 | 06:16 AM
meaj82's Avatar
meaj82
Thanks! just opening up possible options for the borla guys out there w/ non-resonated test pipes.
I know it does not sound like it, but I took it a bit past 6k in the vid.
Old Nov 10, 2007 | 07:05 AM
350Zenophile's Avatar
350Zenophile
I'd like to see a pic of this installed. Does it have to be welded in?
Old Nov 10, 2007 | 07:41 AM
meaj82's Avatar
meaj82
Some quick horrible shots. I will try to get some better one within a day or two. I need to change my oil so I will post some pics then.
Old Nov 10, 2007 | 09:44 AM
350Zenophile
cool. thanks!
Old Dec 6, 2007 | 09:29 AM
baka778's Avatar
baka778
has anyone actually try these x-pipe? instead of the x-muffler.
http://www.magnaflow.com/02product/02xypipes.asp
Old Dec 6, 2007 | 09:35 AM
350Zenophile
Fixed.
I'm curious too. I've heard that welding the stock h-pipe will eliminate the hissing sound on decel, so it would probably fix that, but I doubt it would eliminate any rasp if that is what you thinking.
Old Dec 6, 2007 | 09:45 AM
baka778's Avatar
baka778
thanks for fixing the post!
well my concern is to get a balance of the sound and performance. so i just want to know how much difference will the x-pipe and the x-muffler have for performance.
Old Dec 6, 2007 | 09:49 AM
Jeff92se's Avatar
Jeff92se
The Stillen uses a non-resonated X pipe like the 1st pic. I don't think #2 would work as the pipes point out. The 3rd isn't really a X pipe at all.
Old Dec 6, 2007 | 10:06 AM
Riley07's Avatar
Riley07
I may try #1 if the pipe diameter is right..
Old Dec 6, 2007 | 10:32 AM
meaj82's Avatar
meaj82
If you are running stock manifolds and cats. I would not invest into this. Just weld up the h-pipe and the rest of the exhaust. That should solve any noise issues.
Old Dec 6, 2007 | 10:47 AM
Jeff92se's Avatar
Jeff92se
Just a guess but I would think an X pipe would benefit a dual exhaust regardless of the manifolds and cats used?
Old Dec 6, 2007 | 11:05 AM
meaj82's Avatar
meaj82
On an actual TD yes(ex:hks, greddy). The borla is not in this case. I could be wrong. I guess thats why I never found any info on this. I just went for it.
Old Dec 6, 2007 | 01:14 PM
Jeff92se's Avatar
Jeff92se
yeah for the G sedan, it's a true dual. My fault here.
Old Dec 6, 2007 | 02:01 PM
05Z33's Avatar
05Z33
If I install the x pipe muffler would I have to remove the resonators that sit between the muffler and H pipe, or should I leave those on?
Old Dec 6, 2007 | 02:56 PM
meaj82's Avatar
meaj82
If you want, you can. I didn't, I was to nervous of it changing the note of the exhaust. I know people have had them removed, but were completely stock and were trying to amplify its sound. They are reported postive, I just never heard any clips.
Old Dec 6, 2007 | 06:02 PM
05Z33's Avatar
05Z33
So what is the part number to this x-pipe? Also is this a true x-pipe or is it a muffler?
Old Dec 6, 2007 | 07:22 PM
  #38
meaj82's Avatar
meaj82
Its magnaflow part # 11385. Its a tru-X perforated core.
JjL
East Canada
Jun 12, 2019 03:04 AM
jsunly
Sep 19, 2015 01:22 PM
